- Code:
#include Wire.h
#include MPU6050_light.h
#include Servo.h
#include ServoInput.h
//Define Variables we'll be connecting to
double Setpoint, Input, Output, Gain1, Gain2;
ServoInputPin-3- TR; //angled brackets here
//Signal diveplane from receiver to PWM pin 2
ServoInputPin-2- Switch(800, 1800); //angled brackets here
//switch signal from receiver PWM pin 3 cal for 3Pos switch Transmitter channel 5 (mc-10)
const int NumPositions = 3;
Servo servoTR;
//creates a Servo with the name „servoTR“ =Tiefenruder
MPU6050 mpu(Wire);
void setup()
Serial.begin(9600);
Serial.flush();
Wire.begin();
mpu.begin();
//Serial.println(F("Calculating gyro offset, do not move MPU6050"));
//delay(1000);
mpu.calcGyroOffsets();
Serial.println("Done.");
//Input = mpu.getAngleX();
Setpoint = 100; //0-Referenz of gyro, approx. in degrees servo arm (0...180)
Gain1 = 5;
Gain2 = 7;
servoTR.attach(8); // Servo signal wire (yellow) connected to pin 8
void loop()
mpu.update();
float rudder = TR.getAngle();
// get angle of servo (0 - 180) TR input from receiver
int position = Switch.map(1, NumPositions); // get Switch pos 1-3
if (position ==1)
servoTR.write(Setpoint - mpu.getAngleX() * Gain1);
else if (position==2)
servoTR.write(Setpoint - mpu.getAngleX() * Gain2);
else
Output = rudder; // schleift Senderinput durch zu TR Servo
servoTR.write(Output);
// Serial.print("Switch Position: ");
// Serial.println(position);
// Serial.println(rudder);
// Serial.println("\tY: " + String(mpu.getAngleY()));
// delay(50);
In total there are 11 users online :: 0 Registered, 0 Hidden and 11 Guests
Cheap Arduino Auto leveler
geofrancis- Posts : 323
I just found this video on youtube showing a very cheap arduino based sub leveler based on Atmega328 and a MPU6050 IMU looks interesting, I havent tested it myself.
Deep Diver (Fred), david f and C-3PO like this post
C-3PO- Posts : 95
Re: Cheap Arduino Auto leveler
Deep Diver (Fred), david f and geofrancis like this post
17b- Posts : 9
Hi Guys, inspired by this code and the YT Video i made a leveller/depth controller by myself. All work till now is documented on my HP. Unfortunately its only in german.
Code and Layout can be sent per mail if anyone ist interested.
This is Work in Progress
https://www.rc-sub.de/component/content/article/161-lage-tiefenregler-auf-arduino-basis?catid=27:elektronik-mit-arduino&Itemid=2080
Deep Diver (Fred), david f, C-3PO and geofrancis like this post
C-3PO- Posts : 95
Hi 17b,
Great project - I cannot remember - you might want to check out i2c pullup resistors - not sure if Pro Mini has them on board
I2C and pull-up resistors
For effective data transmission with the Inter-Integrated Circuit (I2C) protocol using Arduino, it’s often necessary to use external pull-up resistors on the designated I2C pins. Most Arduino boards don’t have pre-installed pull-up resistors on these pins, but instead they offer exposed pads for surface mount resistors. This gives more flexibity on how these pins can be used. More specifically:
Regards
C-3PO
Regards
C-3PO
17b- Posts : 9
Hi, the MPU6050 has two 2k2 Resistors onboard. The Leveller works flawlessly
C-3PO likes this post
C-3PO- Posts : 95
Hi 17b,
Great - I did not know that - "everyday is a school day..."
Regards
C-3PO
Regards
C-3PO
17b wrote:Hi Guys, inspired by this code and the YT Video i made a leveller/depth controller by myself. All work till now is documented on my HP. Unfortunately its only in german.
for pid control you should look at this library
https://github.com/br3ttb/Arduino-PID-Library
17b- Posts : 9
I will check it for further improvements. Seems to be easy to use. Exactly the right for me.
BTW, are there actually any levellers out there which use PID? As i know from german manufacturers like Brüggen or Momo, they only use P for their levellers. I still have some old completely analog levellers from Nils Canditt who use PID, but they are discontinued since maybe 10 years or so.
Deep Diver (Fred) and david f like this post
You can just set the I and d to zero if you dont need it for leveling but you will need it for depth control.
17b- Posts : 9
Folks, i nearly finished my depth Controller. As i promised, i will share my Designs and Code. Right now the depth Controller ist very well useable, i use it in my 202 Friedrich Schürer. There is also a second different build with an X-Mixer and no depth sensor. My next step is to merge them into one universal Board, the PCBs from China arrive next week.
Here is a link to my (german) Webpage:
https://www.rc-sub.de/elektronik-mit-picaxe/161-lage-tiefenregler-auf-arduino-basis
Please remember, this is still Work in Progress.
If you have any questions, feel free to ask.
Deep Diver (Fred) and geofrancis like this post
