david f Wed Dec 21, 2016 2:22 pm
Hein's rather useful reply:
Dear Mr. Forrest
I very much hope that the machine translation is understood.
First of all, I would like to wish you and your family the best wishes for the coming holidays, and also all the best wishes for the new year.
Let us hope that all our wishes come true.
As a sporadic visitor to their forum, I found a report on the Krick-boot
Typ 25 or 26. (Wooden hull)
I myself have had such a boat for many years, but I have the original version, which in the 1960 he was still manufactured by Schuco-Hegi. My model had a cover that had been milled from one piece of wood. (Abachi) A short time later, Schuco-Hegi stopped the production. Many years went by, until Krick reintroduced this model into their program. From this time, the model was delivered in layered construction. These layer boards were sawn out in the factory and were glued together from the model- builder.
The opening of the fuselage was closed with a prefabricated (milled) cover made of beech plywood and two long threaded rods and knurled nuts.
The upper deck was molded from ABS and provided with slots.
But the colleague knows this from his own point of view.
If you think that some more insignificant tips can help your colleague, then let me know.
Best regards
Sehr geehrter Herr Forrest
Zuerst möchte ich Ihnen und Ihrer Familie die besten Wünsche zu den bevorstehenden Feiertagen wünschen, und ebenso alle guten Wünsche für das neue Jahr.
Hoffen wir, dass alle unsere Wünsche in Erfüllung gehen.
Als sporadischer Besucher ihres Forums fand ich einen Bericht über das Krick Boot Typ 6.
Ich selbst besitze seit vielen Jahren solch ein Boot, allerdings habe ich die ursprüngliche Variante, die in den 1960 er damals noch von Schuco-Hegi hergestellt wurde. Mein Modell hatte damals eine Hülle, die aus einen Stück Holz gefräst war. Kurze Zeit später stellte Schuco-Hegi die Produktion ein. Viele Jahre vergingen, bis dann Krick dieses Modell wieder in das Programm aufgenommen hat. Ab dieser Zeit wurde das Modell in Schichtbauweise geliefert. Diese Schichtbretter waren in der Fabrik ausgesägt und wurden zusammengeleimt.
Mit einem vorgefertigten (gefrästen) Deckel aus Buchensperrholz wurde über zwei lange Gewindestangen und Rändelmuttern die Öffnung des Rumpfes verschlossen.
Das Oberdeck war aus ABS geformt und mit Schlitzen versehen. Aber das kennt der Kollege ja aus eigener Anschauung.
Wenn Sie meinen, dass einige weitere unmaßgebliche Tipps dem Kollegen helfen können, dann lassen Sie es mich wissen.
» David Forrest's R class
» bladder bags
