Firstly my thanks to Tim Senecal for opening up the use of openLRS and telemetry for model subs.
I have been been using telemetry on openLRS for 2 or 3 years now and it is useful but not in the same way that it is used in model aircraft.
A lot of the measures and sensors are not really very useful for model subs. For example:
GPS - it doesn't work underwater.
Amps - not very important really.
Fuel gauge - ??
Multiple battery voltages - maybe overall battery voltage?
Temperatures - ?
RPM - ?
Compass - useful?
Altitude - yes, but needs to be depth.
Of the list, I've found that battery voltage, depth and compass heading are really useful.
I haven't had much success with various compass modules. They work fine on the bench but in the close confines of a model sub they don't work well, at all. I think that stray magnetic fields from the wiring is the culprit.
So a telemetry system with only 2 values would be useful (and also easier for me with my limited coding skills!) I've been thinking about this for a year or two but the coronavirus lockdown has given me some time and focus. (OK, I'm trying VERY hard to find some benefit from a global crisis!)
So here it is. It is also open source (Please check my Github for the latest software. https://github.com/rdforrest/openLRS ) so you are not tied to any commercial systems and it lends itself to things like Phil Green's home made, Arduino based TX system.
The transmitter is a gutted one modified as per Phil Green's guide. (Hope you like the rubber bands.)The oLED display is showing a lead acid battery voltage (10 volts):
![Simple telemetry system for openLRS (on 458Mhz) 20200510](https://i.servimg.com/u/f61/18/20/23/31/20200510.jpg)
The depth reading (7m) (Only test data!)
![Simple telemetry system for openLRS (on 458Mhz) 20200519](https://i.servimg.com/u/f61/18/20/23/31/20200519.jpg)
Depth reading.
![Simple telemetry system for openLRS (on 458Mhz) 20200514](https://i.servimg.com/u/f61/18/20/23/31/20200514.jpg)
The Arduino Nano Every and the oLED display at the Transmitter end before being heat sleeved. TX battery voltage provides the power and draws about 50mA.
![Simple telemetry system for openLRS (on 458Mhz) 20200517](https://i.servimg.com/u/f61/18/20/23/31/20200517.jpg)
![Simple telemetry system for openLRS (on 458Mhz) 20200516](https://i.servimg.com/u/f61/18/20/23/31/20200516.jpg)
The Hobbyking receiver end. Another Arduino Nano Every acts as the data gatherer
![Simple telemetry system for openLRS (on 458Mhz) 20200518](https://i.servimg.com/u/f61/18/20/23/31/20200518.jpg)
![Simple telemetry system for openLRS (on 458Mhz) 20200513](https://i.servimg.com/u/f61/18/20/23/31/20200513.jpg)
The sketch for the data gatherer Arduino: (Please check my Github for any updates.)
Based on work by Tim Senecal.
For Nano Every. (I have had problems with clones stopping working and requiring sketch to be reloaded.)
Sends data over openLRS Passthru.
To do this, open the openLRS configurator for TX , Set serial baudrate(bps) to 9600, data rate(bps) to 9600, Telemetry to "Yes" (This is Passthru)
Connections to Hobbyking receiver module:
Arduino TX (Pin TXD1) -> receiver RX (Serial port pins, 4th pin down fom top - aerial on left)
Arduino GND -> receiver GND (Serial port pins,1st pin down from top - aerial on left.)
Voltage divider input to A2
Other sensor input (e.g Depth) to A3
Receiver +6v to Vin on arduino
Arduino serial data default is, serial baud rate (9600) and 8 data bits, no parity,no stop,LSB and not inverted - the default
Sept 2019-RDF - Voltage Divider. Move to input from divider set by 4.7kohms and 15k ohms for 12 v battery. Better for 3.3 v input.
(My original depth calibration depth (Using Tim's depth sensor detailed on SubPirates Forum) = 3 * (depth - 84); // 84 to set zero)
void setup() {
// Open USB serial communications and wait for port to open:
Serial.begin(9600);
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
Serial.println("Wake-up-you Serial usb port!");
delay(1000); // We wait 1 second
// Open second hardware serial port
Serial1.begin(9600);
Serial1.println("Wake-up Serial1 port!");
void loop() {
// Read voltage sensor value on A2
int sensorVal = analogRead (A2);
sensorVal = sensorVal / 76; // Fiddle factor (originally 67) is calibration value for voltage from earlier software by RDF
String mysensorVal = String(sensorVal);
// Read depth sensor value on A3
int sensorVal1 = analogRead (A3);
sensorVal1 = sensorVal1 / 100; // Fiddle factor is calibration value
String mysensorVal1 = String(sensorVal1);
// print the voltage sensor value
Serial.println(mysensorVal);
Serial.print('\n'); // new line
delay (200);
// print the voltage sensor value to Serial
Serial.println(mysensorVal1);
delay (200);
Serial1.print(mysensorVal);
delay (200);
Serial1.print('\n'); // new line
delay (200);
// print the voltage sensor value to Serial1
Serial1.print(mysensorVal1);
delay (200);
delay (200);
//Test
//Serial1.print("RDF");
delay(10); // We wait 10mS to print the next value
The sketch for the display Arduino:
Displays 2 streams of data on 0.96 inch oLED display which is visible in sunlight.
Connections to Hobbyking transmitter module:
Identify serial port on module. (6 pins in a line.)
Identify DTR pin. (Usually the left hand pin but it is marked on the back of the board.)
Connect Arduino RX (Pin RXD1) --> TX pin on TX module (next to DTR pin)
Connect Arduino Gnd --> Ground on TX module. (One of 2 pins furthest from DTR)
Power supply: Arduino Vin --> Transmitter battery positive. (You can connect a flying lead into the TX module.)
Nano and display draw about 50mA
Details of OLED display from Banggood:
White 0.96 Inch OLED I2C IIC Communication Display 128*64 LCD Module
VCC: 3.3-5V
GND: Ground
SCL: Serial Clock
SDA: Serial Data
Resolution: 128*64
Color: white
Viewing angle: >160°
Support platform: , 51 series, MSP430 series, STM32/2, chip, etc.
Ultra low power consumption: 0.04W during normal operation
Wide voltage support: DC 3.3V-5V
Working temperature: -30 ° C ~ 80 ° C
Driver chip: SSD1306
Communication method: IIC, only 2 I/O ports
Backlight: OLED self-illumination, no backlight required
Universal 8bit Graphics Library (https://github.com/olikraus/u8g2/)
Copyright (c) 2016, olikraus@gmail.com
All rights reserved.
#include <Arduino.h>
#include <U8g2lib.h>
#ifdef U8X8_HAVE_HW_SPI
#include <SPI.h>
#endif
#ifdef U8X8_HAVE_HW_I2C
#include <Wire.h>
#endif
String inString; // Make global
long bitt = 0; // Make global
U8g2lib Example Overview:
Frame Buffer Examples: clearBuffer/sendBuffer. Fast, but may not work with all Arduino boards because of RAM consumption
Page Buffer Examples: firstPage/nextPage. Less RAM usage, should work with all Arduino boards.
U8x8 Text Only Example: No RAM usage, direct communication with display controller. No graphics, 8x8 Text only.
This is a page buffer example for oLED.
Display Connections: Vcc to 5v. A4 pin is SDA. A5 pin is SCL.
Some fonts:
// u8g2.setFont(u8g2_font_ncenB14_tr);
// 11 Pixel height font
//u8g2.setFont(u8g2_font_ncenB10_tr);
// 14 Pixel font
//u8g2.setFont(u8g2_font_profont22_mf);
// 16 Pixel font
//u8g2.setFont(u8g2_font_crox3hb_tn);
// 49 Pixel Height
//u8g2.setFont(u8g2_font_fur49_tn);
//u8g2.drawStr(20, 55, b);
// 62 Pixel Height
u8g2.setFont(u8g2_font_logisoso62_tn);
// Please UNCOMMENT one of the contructor lines below
// U8g2 Contructor List (Picture Loop Page Buffer)
// The complete list is available here: https://github.com/olikraus/u8g2/wiki/u8g2setupcpp
// Please update the pin numbers according to your setup. Use U8X8_PIN_NONE if the reset pin is not connected
//U8G2_NULL u8g2(U8G2_R0); // null device, a 8x8 pixel display which does nothing
//U8G2_SSD1306_128X64_NONAME_1_4W_SW_SPI u8g2(U8G2_R0, /* clock=*/ 13, /* data=*/ 11, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8);
//U8G2_SSD1306_128X64_NONAME_1_4W_HW_SPI u8g2(U8G2_R0, /* cs=*/ 12, /* dc=*/ 4, /* reset=*/ 6); // Arduboy (Production, Kickstarter Edition)
//U8G2_SSD1306_128X64_NONAME_1_4W_HW_SPI u8g2(U8G2_R0, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8);
//U8G2_SSD1306_128X64_NONAME_1_3W_SW_SPI u8g2(U8G2_R0, /* clock=*/ 13, /* data=*/ 11, /* cs=*/ 10, /* reset=*/ 8);
//U8G2_SSD1306_128X64_NONAME_1_HW_I2C u8g2(U8G2_R0, /* reset=*/ U8X8_PIN_NONE);
//U8G2_SSD1306_128X64_ALT0_1_HW_I2C u8g2(U8G2_R0, /* reset=*/ U8X8_PIN_NONE); // same as the NONAME variant, but may solve the "every 2nd line skipped" problem
//U8G2_SSD1306_128X64_NONAME_1_SW_I2C u8g2(U8G2_R0, /* clock=*/ 13, /* data=*/ 11, /* reset=*/ 8);
U8G2_SSD1306_128X64_NONAME_1_SW_I2C u8g2(U8G2_R0, /* clock=*/ SCL, /* data=*/ SDA, /* reset=*/ U8X8_PIN_NONE); // All Boards without Reset of the Display
// End of constructor list.RDF removed a lot of these.
void setup(void) {
// Open serial communications and wait for port to open:
Serial.begin(9600);
while (!Serial) {
while (!Serial1) {
Serial.print("Wake-up USB!");
//Test oled
u8g2.begin();
u8g2.firstPage();
do {
u8g2.drawStr(0, 15, "DATA RX");
} while ( u8g2.nextPage() );
delay(1000);
void loop(void) {
// This is the function which receives the serial data:
recvWithEndMarker();
delay(200); // We wait 200 mS to print the next value
// Convert integer to character for display ( https://www.instructables.com/id/Converting-integer-to-character/)
long a = bitt;
char b[3]; // define character variable
String str; // define string variable
str = String(a); // convert to string
str.toCharArray(b, 3);
// Print to oLED
u8g2.firstPage();
do {
// 62 Pixel Height
u8g2.drawStr(20, 65, b);
delay(1000);
// Functions:
void recvWithEndMarker() {
Serial connection with String to Integer conversion
Reads a serial input string until it sees a newline, then converts the string
to a number if the characters are digits.
The circuit:
- No external components needed.
created 29 Nov 2010
by Tom Igoe
This example code is in the public domain.
http://www.arduino.cc/en/Tutorial/StringToInt
inString = ""; // string to hold input
// Open serial communications and wait for ports to open:
Serial.begin(9600);
while (!Serial) {
// send an intro:
Serial.println("\n\nString to Int():");
Serial.println();
// Read serial1 input:
while (Serial1.available() > 0) {
int inChar = Serial1.read();
if (isDigit(inChar)) {
// convert the incoming byte to a char and add it to the string:
inString += (char)inChar;
// if you get a newline, print the string, then the string's value:
if (inChar == '\n') {
// Save value as a long integer.RDF
bitt = inString.toInt();
Serial.print("Value:");
Serial.println(inString.toInt());
Serial.print("String: ");
Serial.println(inString);
// clear the string for new input:
inString = "";
Read the comments in the software for a lot of the detail. Please note that you need to set up "Passthru telemetry" for the TX module using the openLRS configurator.
LATER EDIT: 3.6.2020. I have experienced some overheating problems of the Arduino feeding the oLED display. This may be because the display is designed for 3.3 volt logic. So I'm trying voltage level conversion. (3.3v to VDD, 470 ohm resistors in series, 1k ohm resistor then connected to earth for SDA and SCL to convert to 3.3 input.) 4.7 k ohm pullup resistors also fitted for i2c requirement. This is working well so far with no overheating. You can use one of the level shifter boards as an alternative. I am also looking at using a Nokia 5110 display. Cheap, and it may be more visible in bright sunlight. (Although the oLED display seems fine in my (northern!) sunlight.
Fuel gauge - ??
Temperatures - ?
RPM - ?
Compass - useful?
Depth reading.
void setup() {
Serial.begin(9600);
while (!Serial) {
void loop() {
delay (200);
delay (200);
delay (200);
delay (200);
delay (200);
delay (200);
//Test
VCC: 3.3-5V
GND: Ground
SCL: Serial Clock
SDA: Serial Data
Resolution: 128*64
Color: white
#include <SPI.h>
#endif
#include <Wire.h>
#endif
Some fonts:
// 14 Pixel font
// 16 Pixel font
// 49 Pixel Height
// 62 Pixel Height
void setup(void) {
Serial.begin(9600);
while (!Serial) {
while (!Serial1) {
//Test oled
u8g2.begin();
u8g2.firstPage();
do {
delay(1000);
void loop(void) {
long a = bitt;
// Print to oLED
u8g2.firstPage();
do {
// 62 Pixel Height
delay(1000);
// Functions:
The circuit:
created 29 Nov 2010
by Tom Igoe
Serial.begin(9600);
while (!Serial) {
// send an intro:
Serial.println();
inString = "";
» David Forrest's R class
» bladder bags
