use of 458MHz modules 14212712
In total there are 52 users online :: 0 Registered, 0 Hidden and 52 Guests :: 1 Bot
use of 458MHz modules EmptyTue Oct 29, 2024 4:46 pm by tsenecal
use of 458MHz modules EmptySun Oct 20, 2024 2:04 pm by geofrancis
use of 458MHz modules EmptyThu Oct 17, 2024 2:34 pm by geofrancis
use of 458MHz modules EmptyMon Oct 14, 2024 4:31 pm by geofrancis
use of 458MHz modules EmptySat Oct 12, 2024 3:52 pm by geofrancis
use of 458MHz modules EmptyFri Oct 11, 2024 8:58 pm by Marylandradiosailor
use of 458MHz modules EmptyFri Oct 11, 2024 8:14 pm by geofrancis
use of 458MHz modules EmptyThu Oct 10, 2024 3:21 am by tsenecal
use of 458MHz modules EmptyWed Oct 02, 2024 11:32 am by geofrancis
    SimonH
    use of 458MHz modules Empty use of 458MHz modules
    Post  SimonH Thu Oct 01, 2020 10:27 pm
    As a newcommer I have no rc equipment at he moment and the only new stuff is the 2.4GHz band with all its problems. I've seen various 458MHz RF modules that would seem to be able to form the basis of a RC system, whilst there are various posts about the commercial modules at the USA frequencies has anybody built a system with the bare 458MHz modules?
    I have also seen a video about swapping the provided 2.4GHz aerial for a longer length of co-ax so that the aerial can poke out of the water via the scope/snorkel that would at least allows running at scope depth. It seems to either rely on the Rx having the aerial wire on a connector or being able to solder fine wires. I could solder that but its easier to just plug a small connector onto the Rx board, so I was wondering if any one had tried that with currently avaialble rc kit, and if so which Rx have a connector?
    I'm think of actual control not a telemetry return feed.
    use of 458MHz modules Empty Re: use of 458MHz modules
    Post  tsenecal Fri Oct 02, 2020 6:51 am
    if you search this site using the term "openlrs" you will find an entire set of threads on how David has built and uses 458mhz equipment exclusively in several of his submarnies.
      Current date/time is Thu Nov 21, 2024 10:21 am
