ESC for a LiPo pack? 14212712
In total there are 43 users online :: 0 Registered, 0 Hidden and 43 Guests :: 1 Bot
ESC for a LiPo pack? EmptyTue Oct 29, 2024 4:46 pm by tsenecal
ESC for a LiPo pack? EmptySun Oct 20, 2024 2:04 pm by geofrancis
ESC for a LiPo pack? EmptyThu Oct 17, 2024 2:34 pm by geofrancis
ESC for a LiPo pack? EmptyMon Oct 14, 2024 4:31 pm by geofrancis
ESC for a LiPo pack? EmptySat Oct 12, 2024 3:52 pm by geofrancis
ESC for a LiPo pack? EmptyFri Oct 11, 2024 8:58 pm by Marylandradiosailor
ESC for a LiPo pack? EmptyFri Oct 11, 2024 8:14 pm by geofrancis
ESC for a LiPo pack? EmptyThu Oct 10, 2024 3:21 am by tsenecal
ESC for a LiPo pack? EmptyWed Oct 02, 2024 11:32 am by geofrancis
    ESC for a LiPo pack? Empty ESC for a LiPo pack?
    Post  Tom(ADMIN) Thu Nov 07, 2013 3:38 pm
    David Forrest, help me out here, please! You're the resident LiPo expert...
    I've had a look round at LiPo friendly esc's, and now I'm totally and utterly confused. Do I really need a programmable esc? What the hell is a programmable esc anyway? All I really want is an esc to run off my LiPo battery pack (3S, 11.1v, 5000a/h...you know the one), to be able to handle a 545 brushed low drain motor, and to cut the power off when the battery pack voltage drops to save the battery from damage.
    Is there such a thing that I can just plug it in, turn it on, and go sailing without all the technical stuff?
    (confused from Sussex....)
    ESC for a LiPo pack? Empty Re: ESC for a LiPo pack?
    Post  Tom(ADMIN) Thu Nov 07, 2013 3:50 pm
    I think I may have found one, courtesy of Andy L...
    ESC for a LiPo pack? 40fr_e10
    Description taken from www.microgyros.com
    * waterproof
    * choice of 4 operating frequencies for smooth and quiet operation
    * variable soft start
    * Internal 5.3v BEC or operates with receiver packs (2s Lipo,LiFe,4,5 or 6 cell NiCd or Nimh)
    * Low voltage cutout,slow down or indication for 2s,3s,4s lipo batteries
    * indication on bec supply or receiver pack below 4.0 volt
    Post  david f Thu Nov 07, 2013 5:35 pm
    Well you can go that route, Richard. But I don't think there is yet a really satisfactory esc for lipos yet.
    (BTW I see that Mtroniks also do escs for lipos - if you don't want to use Microgyros - they are a very small outfit.)
    The problem is that they all seem to indicate low voltage by a reduction in speed. Would you notice that ?? (Weed patch, radio gremlin etc.) It is much clearer for electric r/c aircraft!
    I just use a simple total voltage sensor which triggers an audible alarm - which I may notice when I bring the sub close. This is not a perfect system either. Flashing light? - awkward to connect up.
    In practice, I never run my lipo driven subs for longer than about 30 minutes so I have loads of capacity left. I have never damaged a lipo in about 5 years of operation. (On a risk basis, I have had several instances of "total sub - loss" in that period and for that you need a Pinger.)
    So maybe just use a standard esc (probably much cheaper) and don't run your sub for too long.
    I'm sure that this answer will not satisfy the theoreticians - but it works!
    Post  Tom(ADMIN) Thu Nov 07, 2013 5:49 pm
    I've plenty of Mtroniks esc's, so maybe I'll use one of those. With 5000a/h and a low drain 545 motor, I guess I'll get plenty of run time?
    Post  david f Fri Nov 08, 2013 8:37 am
    Several hours I would think, Richard.
    You can also buy some neat little lipo voltage monitors which plug into the balancing (i.e charging) socket. Green leds change to red leds to give you a visual indication through the WTC.
    So with a large capacity lipo and being conservative on run times you should be OK with standard ESCs.
    Post  Tom(ADMIN) Fri Nov 08, 2013 9:04 am
    Thanks David,
    I'll give that a try before I give my flexible friend another beating, I can hear it trembling in my wallet as I type this...
    The LiPo charge bag arrived this morning, and I only ordered it yesterday! Cracking piece of kit it is too, well pleased with it.
    ESC for a LiPo pack? Photo_63
    Post  Tom(ADMIN) Fri Nov 08, 2013 9:19 am
    Is this the sort of voltage monitor you mean, David?
    http://www.sussex-model-centre.co.uk/shopexd.asp?id=43764
    ESC for a LiPo pack? Koko-b10
    Post  david f Fri Nov 08, 2013 1:04 pm
    That  tooks like a nice one.
    Mine is simpler just red and green LEDs for each cell.
    Presumably the display gives the total voltage which isn't all that useful, because you will find that cells discharge at different rates and what is useful to know  is when the first cell goes "red".
    But if that unit gives individual cell indications and a total voltage that should do nicely.
    And yes why not save the flexible friend.
    ESCs for Lipos seem to be expensive and are still far from perfect for submarines, in my opinion.
    PS Just been having a look at the unit you gave the link for. You can get individual cell voltages but it mentions a push button. You may not want to undo loads of bolts to push a tiny button?!
    Post  Tom(ADMIN) Fri Nov 08, 2013 2:44 pm
    I've just ordered one, so we'll soon see what they are like, David...at a penny shy of £4.00 it'll hardly cause my flexible friend to break out into a sweat.
    If it's ok, I can mount it under the access hatch on the box lid so I can see it.
    Post  Giovanni LiCalsi Fri Nov 22, 2013 5:18 pm
    You can also find audible plugin battery monitors.
      Current date/time is Thu Nov 21, 2024 9:07 am
