willie skipjack no2 14212712
In total there are 32 users online :: 0 Registered, 0 Hidden and 32 Guests :: 1 Bot
willie skipjack no2 EmptyTue Oct 29, 2024 4:46 pm by tsenecal
willie skipjack no2 EmptySun Oct 20, 2024 2:04 pm by geofrancis
willie skipjack no2 EmptyThu Oct 17, 2024 2:34 pm by geofrancis
willie skipjack no2 EmptyMon Oct 14, 2024 4:31 pm by geofrancis
willie skipjack no2 EmptySat Oct 12, 2024 3:52 pm by geofrancis
willie skipjack no2 EmptyFri Oct 11, 2024 8:58 pm by Marylandradiosailor
willie skipjack no2 EmptyFri Oct 11, 2024 8:14 pm by geofrancis
willie skipjack no2 EmptyThu Oct 10, 2024 3:21 am by tsenecal
willie skipjack no2 EmptyWed Oct 02, 2024 11:32 am by geofrancis
    willie skipjack no2
    willte
    willie skipjack no2 Empty willie skipjack no2
    Post  willte Mon Dec 16, 2013 5:31 pm
    willie skipjack no2 00410
    willie skipjack no2 Empty Re: willie skipjack no2
    Post  Tom(ADMIN) Mon Dec 16, 2013 5:40 pm
    That's a big cylinder...
    willte
    Post  willte Mon Dec 16, 2013 6:02 pm
    not that big when you see the battery 2x6voltx4amp jell type takes the tube down in the water for a nice draft
    Post  Tom(ADMIN) Mon Dec 16, 2013 6:17 pm
    Mine has a 24" long, 80mm diameter cylinder, with a water pump ballast system.
    Post  david f Wed Dec 18, 2013 9:16 am
    Hi Willte,
    Interesting photos. I think I can see why you are looking for aluminium tubing of a specific size. Is it because you are using the same commercial end caps for different submarines?
    If so there is one skill/availability that would really help you with subs - Lathe access either your own or someone elses. End caps with O ring seals are not very difficult to make.
    willte
    Post  willte Wed Dec 18, 2013 5:20 pm
    I know DAVID if I was still working   i would have made my own  I am a lathe turner by trade  trouble is finding a lathe in Lossie with all the places that had one are now closed all was  fancy but the price for a big one and where to keep it bets me but I have this one for swillie skipjack no2 00210mall jobs also a milling machine to fit it
    Post  david f Thu Dec 19, 2013 8:42 am
    Yes, where to keep a lathe is a big problem for most people. I inherited my Dad's Myford lathe but had nowhere to keep it.
    I now compromise with a US made Taig (Known as a Peatol in the UK) lathe which is not much bigger than yours. With riser blocks fitted (a lot of people forget about riser blocks) I can turn 110mm diameter polycarbonate without problems.
    willte
    Post  willte Thu Dec 19, 2013 10:47 am
    where do you get your blanks from david
    Post  david f Thu Dec 19, 2013 12:12 pm
    I have a large sheet of 6mm "smoked" tinted polycarbonate sheet which I found by the bins at the flat I used to live in. (I think it was probably used as a security screen somewhere. No, I didn't take it during an armed robbery!)
    I bond 3 layers of this together using Plastic Weld. (Drizzle the solvent on and quickly clamp it up. Best done outside.)
    Let it mature for a day and you have a good thick blank which is good for end caps.
    I'm sure you can buy thick polycarbonate but it will probably be expensive. Polycarbonate is my favourite material for lots of things - incredibly tough but easy to machine. I used to to have trouble cutting it with power tools - the cut sticks back together. Following Nigel's suggestion I now use one of new generation (and quite cheap) handsaws. An 11 teeth per inch (Stanley Fat Max from B & Q) one seems to work well.
    willte
    Post  willte Thu Dec 19, 2013 4:38 pm
    ever tried Vaseline when cutting it nothing sticks to it , and wipe it clean with white spirit or paint thinner
    willte
    Post  willte Thu Dec 19, 2013 5:48 pm
    motorwillie skipjack no2 00211 and gearbox
    Post  Tom(ADMIN) Thu Dec 19, 2013 6:10 pm
    End caps by MMB?
    Post  nigele(ADMIN)2 Thu Dec 19, 2013 6:14 pm
    Just a word off warning Guy's,if you want to cut poly wet just use soapy water and a course blade,don't use thiners on poly it will attack it and over time it will craze,the same applies to thread lock(loctite etc).
    willte
    Post  willte Thu Dec 19, 2013 7:00 pm
    that where I got them the same type that in the sea wolf, had a look in e-bay but what a price,but £10 for two at MMB
      Current date/time is Thu Nov 21, 2024 10:19 am
