How to choose a speed controller 14212712
In total there are 29 users online :: 0 Registered, 0 Hidden and 29 Guests
How to choose a speed controller EmptyTue Oct 29, 2024 4:46 pm by tsenecal
How to choose a speed controller EmptySun Oct 20, 2024 2:04 pm by geofrancis
How to choose a speed controller EmptyThu Oct 17, 2024 2:34 pm by geofrancis
How to choose a speed controller EmptyMon Oct 14, 2024 4:31 pm by geofrancis
How to choose a speed controller EmptySat Oct 12, 2024 3:52 pm by geofrancis
How to choose a speed controller EmptyFri Oct 11, 2024 8:58 pm by Marylandradiosailor
How to choose a speed controller EmptyFri Oct 11, 2024 8:14 pm by geofrancis
How to choose a speed controller EmptyThu Oct 10, 2024 3:21 am by tsenecal
How to choose a speed controller EmptyWed Oct 02, 2024 11:32 am by geofrancis
    Manuel Garcia
    How to choose a speed controller Empty How to choose a speed controller
    Post  Manuel Garcia Sat Jul 25, 2015 9:47 pm
    I am new to rc submarines and I am building a typhoon class Russian submarine from scratch. I have two dc motors from a printer and I don't know what speed controller should I use. Each one consumes 700 ma ( with no charge) and 2,5 amp under pressure. I am going to use a 11,1 V lithium battery, so should I use a foward-reverse 6 amp speed controller? And where can I get one ? Thank you
    How to choose a speed controller Empty Re: How to choose a speed controller
    Post  david f Sat Aug 01, 2015 10:34 am
    Hi Manuel,
    The 2.5 amp (stall?) current is a good guide for selection but multiply it by a few times. (Hold the shaft and measure the maximum current.)
    So 10 amp ESCs or so would be OK.
    And yes, one per motor.) and a channel each will give you the most control. (You may be able to do static turns but this can be hard with subs - props too close together.)
    Microgyro and Mtronik are both good suppliers which I have used.
    (Try searching using the term ESC on this forum for more info.)
    Manuel Garcia
    Post  Manuel Garcia Sun Aug 16, 2015 1:15 pm
    Thanks for your answer, David ;
    And yes, 2.5 amp was measured in stall.
    I have purchased a viper marine micro 10 from mtronics and I thought that the easiest way to turn was with a ruder, using the same speed controller for the two motors, putting a fuse for more safety, as I saw in other models.
      Current date/time is Thu Nov 21, 2024 9:02 am
