having a go at rebuilding an 80" scratch built Seaview. So far I have removed the window frames from the observation lounge, removed about 1Lb of Fibre glass and resin from inside the hull which had been poured in and shaken about from the look of it have also sorted out the engine nacells? sourced new 55o motors for her she came with a Sheerline tube, I saw the sub running at my local lake about 18 months ago and liked what I saw unfortunatley the sub was then left in disrepair in a garage
In total there are 11 users online :: 0 Registered, 0 Hidden and 11 Guests :: 1 Bot
80" Seaview
thegrimreaper- Guest
80" Seaview
Hi guys,
80" Seaview
Re: 80" Seaview
Looking good, Mark!
When I look at that bow and those windows I can't help but get a nostalgic glow!
I remember seeing the original movie in a cinema as a child. (On holiday at Newquay with my sister and a friend.) Those were the days when it was a continuous programme so we sat through the film twice (money saving also!) Magic.
Cut to the present. I'm looking forward to seeing that Seaview sailing, Mark. Even with all the fans it is a rare topic for modellers in the UK. I have seen one or two on exhibition stands but none sailing.
John Wrennall- AMS member
Re: 80" Seaview
I recall Alan Warehand working on one at a St Albans dive-in a few years back but unfortunately don't remember it sailing.
Re: 80" Seaview
Funny that John because we were at that dive in ourselves and saw the same model you saw there
Mark.
Mark.
merriman- Guest
Re: 80" Seaview
Some r/c SEAVIEW eye-candy for you:
https://www.youtube.com/watch?v=fBDPOvyZdAg
https://youtu.be/3rK4jZK-PrA
https://youtu.be/OyEsOI2lvkA
Re: 80" Seaview
Thank you for the 3 links God,
I have just found a video of the model I now own I have also found a cut and join in the upper and lower hull some one at some time has removed 6" from the length, but I can live with that she fits in the car no problem stripped everything out ready for replacement of all control surfaces tubes have been cleaned up but I think will need a lining inside 4 blade brass props with geared motors were the power plants, I think I know who the builder was through a bit of investigation and the tinternet
thank you again for the links David.
regards Mark.
Correction to this post the Hull has not been cut at all originally was 80" and still is, cracks were just that cracks in the gel coat which have now been repaired, more to follow with pictures soon.
Mark
regards Mark.
Mark
timgarrod- AMS Website Webmaster
Re: 80" Seaview
Very nice video Merriman. Cant wait to see your finish Mark
update
a fare bit of cleaning up of the hull to get rid of a right build up of resin drips and unknown rubbish in the hull including wet soggy wood pieces also fitted a plastic lip to the hull top to assist with aligning the top hull to the bottom hull
update
Filled in what seemed to be a hundred flood holes all along the bottom of the hull I will be re drilling a few holes and making them slightly larger than the ones that have been filled
The bottom picture is the piece that I cut out of the bottom hull which represents the flying sub bay which is the wrong shape and will be corrected this piece will be reused for patrol duties and will be replaced by a lighter more detailed version for display purposes
Last edited by thegrimreaper on Sat Aug 20, 2016 9:21 am; edited 1 time in total (Reason for editing : additional text)
Re: 80" Seaview
A major problem has been found on the Seaview the rear "Cadillac" wings have been fitted at the wrong angle according to the Blueprint I have soooo !! I removed them cleaned everything up re measured re marked (3 times) then refitted into the correct position and I say it myself they look much better now a little lower than the near vertical line they had.
Still got mountains to do but am enjoying myself will be a while before she sees water again but I will get there early days yet
thanks for looking
Mark
thanks for looking
Mark
Last edited by thegrimreaper on Sat Aug 20, 2016 9:30 am; edited 1 time in total (Reason for editing : additional text again)
Re: 80" Seaview
Looking good, Mark.
Free flooding holes on models are always annoying to me. They are never quite big enough to work properly! It's a trade off between effectiveness and scale appearance. (I think it is because surface- tension doesn't "scale" well and they don't provide free flow.)
another update
Just taken another picture cropped it and now discover I have an after and a before work shot of the rear "Cadillac" wings
please let me know what you think i.e. better worse or just the same
Me,? I think they look just about right now bit more work needed on the wing root but will get there
Last edited by thegrimreaper on Sat Aug 20, 2016 10:06 am; edited 2 times in total (Reason for editing : text reversal)
merriman- Guest
- Post n°14
Re: 80" Seaview
No doubt about it -- you're repositioning of the vertical stabilizers was the right move. Keep at it!
