Receiver aerial  14212712
In total there are 40 users online :: 0 Registered, 0 Hidden and 40 Guests :: 1 Bot
Receiver aerial  EmptyTue Oct 29, 2024 4:46 pm by tsenecal
Receiver aerial  EmptySun Oct 20, 2024 2:04 pm by geofrancis
Receiver aerial  EmptyThu Oct 17, 2024 2:34 pm by geofrancis
Receiver aerial  EmptyMon Oct 14, 2024 4:31 pm by geofrancis
Receiver aerial  EmptySat Oct 12, 2024 3:52 pm by geofrancis
Receiver aerial  EmptyFri Oct 11, 2024 8:58 pm by Marylandradiosailor
Receiver aerial  EmptyFri Oct 11, 2024 8:14 pm by geofrancis
Receiver aerial  EmptyThu Oct 10, 2024 3:21 am by tsenecal
Receiver aerial  EmptyWed Oct 02, 2024 11:32 am by geofrancis
    Receiver aerial
    antoak
    Receiver aerial  Empty Receiver aerial
    Post  antoak Sat Jun 30, 2018 6:57 pm
    As someone new to model submarines, I am building the Arkmodel German V11C, I thought I would start off with an easy (I asume) question. Can the aerial for a 72 Mhz receiver be run outside of the water tight compartment. This would give the aerial a straighter run and keep it away from other metal components.
    Many thanks
    Tony
    timgarrod
    AMS Website Webmaster
    Receiver aerial  Empty Re: Receiver aerial
    Post  timgarrod Sat Jun 30, 2018 7:05 pm
    not a problem just remember to seal the end to stop water getting in.
    i got them running both inside and out.
    Post  merriman Sat Jun 30, 2018 11:49 pm
    antoak wrote:As someone new to model submarines, I am building the Arkmodel German V11C, I thought I would start off with an easy (I asume) question. Can the aerial for a 72 Mhz receiver be run outside of the water tight compartment.  This would give the aerial a straighter run and keep it away from other metal components.
    Many thanks
    Tony
    Yes. For the reasons you stated.
    But it's a good idea to isolate the antenna in the wet from the dry insides of the WTC. This is done by providing a conducting interface between the receiver and external antenna segments. That is done with a stud screwed through the after 'motor-bulkhead'. A nut at either end of the stud completes the connection between receiver and external antenna.
    You don't want to simply run the antenna between the receiver and the wet without a blocking interface between the dry and wet side of the antenna. Eventually water will get past the insulation and wick its way onto the receiver PCB, killing the device.
    Sounds impossible, but I've seen it happen. The unlucky guy (well, maybe not … he did get his boat back), during the post accident investigation, pulled the case off the receiver and everything inside was wet. Water, over a five year period, found its way!
    Receiver aerial  YnZqTU
    To isolate the bare antenna wire from the wet side, I smear RTV silicon rubber over the stud, nut, and bare antenna wire sandwiched between nut and washer. Note that I provide an antenna strain-relief by drilling a hole through the motor-bulkhead flange and reeving the antenna through it. Accidental pulling on the antenna wire won't lift it off the RTV insulation.
    Receiver aerial  WHFMfS
    antoak
    Post  antoak Sun Jul 01, 2018 7:26 pm
    Thanks for replies. Very useful information.
    Tony
    cgbillb
    cgbillb
    Receiver aerial  Empty Your Sub
    Post  cgbillb Wed Jul 11, 2018 12:48 am
    I have the same kit, but my WTC shafts did not line up very well with the prop shafts
    Where did you get your WTC? I see it lines up much better than mine
    Thanks for any help
    Bill
    Athens Ga.
    Post  merriman Wed Jul 11, 2018 2:27 am
    cgbillb wrote:David
    Thanks for any help
    Bill
    Athens Ga.
    https://www.rc-submarine.com/watertightcylinders
    cgbillb
    cgbillb
    Receiver aerial  Empty Thamks
    Post  cgbillb Wed Jul 11, 2018 3:34 am
    Thanks, that is where I go mine
    Bill
      Current date/time is Thu Nov 21, 2024 9:14 am
