Compatibility issue.. 14212712
In total there are 38 users online :: 0 Registered, 0 Hidden and 38 Guests
Compatibility issue.. EmptyTue Oct 29, 2024 4:46 pm by tsenecal
Compatibility issue.. EmptySun Oct 20, 2024 2:04 pm by geofrancis
Compatibility issue.. EmptyThu Oct 17, 2024 2:34 pm by geofrancis
Compatibility issue.. EmptyMon Oct 14, 2024 4:31 pm by geofrancis
Compatibility issue.. EmptySat Oct 12, 2024 3:52 pm by geofrancis
Compatibility issue.. EmptyFri Oct 11, 2024 8:58 pm by Marylandradiosailor
Compatibility issue.. EmptyFri Oct 11, 2024 8:14 pm by geofrancis
Compatibility issue.. EmptyThu Oct 10, 2024 3:21 am by tsenecal
Compatibility issue.. EmptyWed Oct 02, 2024 11:32 am by geofrancis
    Compatibility issue.. Empty Compatibility issue..
    Post  Tom(ADMIN) Wed Dec 29, 2010 9:05 am
    Can someone tell me please, if this rx will be compatible with my HiTec Optic 6 tx?...Compatibility issue.. Hitec_10
    This small receiver is a HITEC HFS-06MT on 40 MHZ
    ITS A FULL RANGE RECEIVER AND TAKES STANDARD SIZE CRYSTALS.
    SIZE 37X 25 X18 MM,
    WEIGHT 15.5 GRAMS,
    6 CHANNEL SINGLE CONVERTION.
    Compatibility issue.. Empty Re: Compatibility issue..
    Post  david f Wed Dec 29, 2010 9:51 am
    I'm sure it will be. (I assume that the transmitter is fairly standard i.e FM, ppm etc)
    Post  Tom(ADMIN) Wed Dec 29, 2010 10:56 am
    That's correct David, it's a computer tx with all sorts of modes on it. I'll give it a try and see what happens..if there's a big bang, a cloud of smoke and a lot of bad language issuing forth from the Sussex area, you'll know it wasn't compatible...
    Post  david f Fri Dec 31, 2010 12:22 pm
    And presumably it uses standard Futaba crystals?
    I'm sure it be fine.
    Post  Tom(ADMIN) Fri Dec 31, 2010 12:25 pm
    I use genuine HiTec crystals, I was lucky enough to buy two sets from a guy on another forum, and yes...that rx did work perfectly with the Optic6 tx.
      Current date/time is Thu Nov 21, 2024 9:17 am
