Air pump & solenoid valve 14212712
In total there are 35 users online :: 0 Registered, 0 Hidden and 35 Guests :: 1 Bot
Air pump & solenoid valve EmptyTue Oct 29, 2024 4:46 pm by tsenecal
Air pump & solenoid valve EmptySun Oct 20, 2024 2:04 pm by geofrancis
Air pump & solenoid valve EmptyThu Oct 17, 2024 2:34 pm by geofrancis
Air pump & solenoid valve EmptyMon Oct 14, 2024 4:31 pm by geofrancis
Air pump & solenoid valve EmptySat Oct 12, 2024 3:52 pm by geofrancis
Air pump & solenoid valve EmptyFri Oct 11, 2024 8:58 pm by Marylandradiosailor
Air pump & solenoid valve EmptyFri Oct 11, 2024 8:14 pm by geofrancis
Air pump & solenoid valve EmptyThu Oct 10, 2024 3:21 am by tsenecal
Air pump & solenoid valve EmptyWed Oct 02, 2024 11:32 am by geofrancis
    Cliffhanger67
    Air pump & solenoid valve Empty Air pump & solenoid valve
    Post  Cliffhanger67 Wed Apr 21, 2021 5:51 pm
    I been struggling with the pump and solenoid valve I bought from a sub resource store.
    It takes forever to compress the air to dive. Also can only compress to 8 psi. The valve leaks.
    Parker Hannifin makes these with million cycles reliability. It made my boat ballast system work great.
    My pump is part no. E222-13
    Valve is:991-000506-007
    Len Morris
    Air pump & solenoid valve Empty Re: Air pump & solenoid valve
    Post  Len Morris Thu Apr 22, 2021 8:19 pm
    Hi Cliffhanger,
    Can't really help with the part numbers and makers you mention, BUT, I'll tell you what I use.
    I have a blood pressure problem and must monitor it daily. The piece of kit I use for this is openly available from any chemist (pharmacy) shop in the UK for about £15 and runs on 6 volt. The pressure it produces in the arm band is powerful and quick.
    Bought a second unit and pulled it apart. Pump, motor, non return valves, etc all for next to nothing.
    My local chemist can't understand why I've bought four of them now!
    Len
    Michaelc
    Air pump & solenoid valve Empty Blood pressure monitor
    Post  Michaelc Fri Apr 23, 2021 11:58 am
    Hi, interested in knowing more re the blood pressure monitor. I looked up a few sites but they are asking over £50 for them. May I ask what make etc you are buying
    Len Morris
    Post  Len Morris Sat Apr 24, 2021 10:34 am
    Hi Michael,
    I buy mine from LLoyds Pharmacy. Currently priced at £21.99. Prices do seem to have gone up a bit but remember you're going to pull it apart and don't need all the 'bells and whistles' that manufacturers seem to add on to them to charge more. I suspect the pump and valves are made by one company and simply repackaged by the different suppliers. Also try ebay. Many people only need a meter for a short while and then almost throw them away.
    Len
    Michaelc
    Air pump & solenoid valve Empty Thanks
    Post  Michaelc Sat Apr 24, 2021 11:22 am
    Thanks. I will take a look.
      Current date/time is Thu Nov 21, 2024 9:05 am
