Pump for bladder system 14212712
In total there are 27 users online :: 0 Registered, 0 Hidden and 27 Guests
Pump for bladder system EmptyTue Oct 29, 2024 4:46 pm by tsenecal
Pump for bladder system EmptySun Oct 20, 2024 2:04 pm by geofrancis
Pump for bladder system EmptyThu Oct 17, 2024 2:34 pm by geofrancis
Pump for bladder system EmptyMon Oct 14, 2024 4:31 pm by geofrancis
Pump for bladder system EmptySat Oct 12, 2024 3:52 pm by geofrancis
Pump for bladder system EmptyFri Oct 11, 2024 8:58 pm by Marylandradiosailor
Pump for bladder system EmptyFri Oct 11, 2024 8:14 pm by geofrancis
Pump for bladder system EmptyThu Oct 10, 2024 3:21 am by tsenecal
Pump for bladder system EmptyWed Oct 02, 2024 11:32 am by geofrancis
    Pump for bladder system Empty Pump for bladder system
    Post  geofrancis Wed May 10, 2023 12:55 pm
    I have been trying to find bidirectional water pumps, does this one look like it would work? the only other ones I have seen are peristaltic pumps buit they are rather slow. or should i just get a pair of diaphram pumps? one for in and one for out.
    https://www.aliexpress.com/item/1005004264135231.html
    found another one that might work.
    https://www.ebay.co.uk/itm/314508591141
    maxx78
    Pump for bladder system Empty Re: Pump for bladder system
    Post  maxx78 Wed May 10, 2023 3:27 pm
    the pump from Ebay is geared pump and in my experience they do not hold the pressure and you lose ballast over time.
    On my first try i pinched the hose with a servo to prevent the bladder from empting itself.
    There are some powerful peristalic pumps but you need some space for them.
    The Grothen G1128 does 700ml/min:  https://www.aliexpress.com/item/1005004028135569.html
    i couldn't find any dimesions for it, only for the G28 model which provides 500ml /min : https://de.aliexpress.com/item/1005004524631196.html
    Post  tsenecal Wed May 10, 2023 6:44 pm
    i agree with maxx78 on both counts:
    1) geared pump == bad, peristaltic == good
    2) flow means everything, and you want something that will fill the bag in 20 seconds or less.
    but i will add these:
    3) most of the 400 size motor pumps (motor is 28mm or so in diameter) are too small to be effective
    4) if the seller doesn't post a flow rate, it is not worth looking at
    5) if you don't find a pump that will fill fast enough, use more volts. (buy the 12v model, run it at 24v)
    6) good peristaltic pumps aren't cheap
    i just got one of these:
    https://www.ebay.com/itm/284844980346
    this is just an example, although this seller is in america, they come from china, so you should be able to find an international seller.
    Post  geofrancis Wed May 10, 2023 9:06 pm
    this one looks like it might tick all the boxes
    https://www.aliexpress.com/item/32817707131.html
    tsenecal likes this post
    Post  tsenecal Wed May 10, 2023 10:34 pm
    I agree with you on that pump, one recommendation, use the "Pharmed BPT tube" version. that tubing lasts longer and is more flexible than the silicon tubing.
      Current date/time is Thu Nov 21, 2024 9:00 am
