Bending brass tube....the Alf way. EmptyYesterday at 4:46 pm by tsenecal
Bending brass tube....the Alf way. EmptySun Oct 20, 2024 2:04 pm by geofrancis
Bending brass tube....the Alf way. EmptyThu Oct 17, 2024 2:34 pm by geofrancis
Bending brass tube....the Alf way. EmptyMon Oct 14, 2024 4:31 pm by geofrancis
Bending brass tube....the Alf way. EmptySat Oct 12, 2024 3:52 pm by geofrancis
Bending brass tube....the Alf way. EmptyFri Oct 11, 2024 8:58 pm by Marylandradiosailor
Bending brass tube....the Alf way. EmptyFri Oct 11, 2024 8:14 pm by geofrancis
Bending brass tube....the Alf way. EmptyThu Oct 10, 2024 3:21 am by tsenecal
Bending brass tube....the Alf way. EmptyWed Oct 02, 2024 11:32 am by geofrancis
    Bending brass tube....the Alf way. Empty Bending brass tube....the Alf way.
    Post  Tom(ADMIN) Wed Feb 23, 2011 7:15 pm
    Here's a brilliant trick from the maestro of metal...Alf Blake.
    If you need to bend a piece of brass tube, try this: plug one end of the tube, and fill the tube with a 50/50 mix of water and washing up liquid, plug that end and pop the tube into the freezer.
    After it's frozen solid, take the tube out and you'll find you can bend it way past 90 degrees without the tube folding or creasing...brilliant!
    Thanks Alf!!
    Bending brass tube....the Alf way. Empty Re: Bending brass tube....the Alf way.
    Post  nigele(ADMIN)2 Wed Feb 23, 2011 8:10 pm
    Don't forget to aneal the tube first or it will split,heat cherry red and then into cold water,do the bend in one movement slow and steady.
    Post  Tom(ADMIN) Wed Feb 23, 2011 9:21 pm
    Alf never said nowt about doing that?
    Post  nigele(ADMIN)2 Wed Feb 23, 2011 9:25 pm
    You know Alf he would assume that everyone knows that.
    Post  Tom(ADMIN) Wed Feb 23, 2011 9:28 pm
    Yea...true.
      Current date/time is Wed Oct 30, 2024 10:52 am
