Making weights 14212712
In total there are 10 users online :: 0 Registered, 0 Hidden and 10 Guests :: 1 Bot
Making weights EmptyTue Oct 29, 2024 4:46 pm by tsenecal
Making weights EmptySun Oct 20, 2024 2:04 pm by geofrancis
Making weights EmptyThu Oct 17, 2024 2:34 pm by geofrancis
Making weights EmptyMon Oct 14, 2024 4:31 pm by geofrancis
Making weights EmptySat Oct 12, 2024 3:52 pm by geofrancis
Making weights EmptyFri Oct 11, 2024 8:58 pm by Marylandradiosailor
Making weights EmptyFri Oct 11, 2024 8:14 pm by geofrancis
Making weights EmptyThu Oct 10, 2024 3:21 am by tsenecal
Making weights EmptyWed Oct 02, 2024 11:32 am by geofrancis
    Making weights
    Making weights Empty Making weights
    Post  david f Sat Apr 02, 2011 12:14 pm
    The photo shows the latest "crazy" idea that works! (I've recovered from the paint fumes now, honest)
    I call it "Wubber". ("Wilicone" was quickly rejected!)
    Making weights Wubber10
    Mix up some lead shot (I buy mine from Hunting, Shooting and Fishing shops) with some silicone rubber. You've then got a stiff goo which can be packed inside the hull. It has a little flex when set but will not shift.
    I've used resin for this in the past but resin is runny and smells and sets too hard. (Not suitable for the near-organic U uPVC class!)
    Making weights Empty Re: Making weights
    Post  Tom(ADMIN) Sat Apr 02, 2011 12:25 pm
    Wubber? David, I'm seriously worried about you, I weally am.
    But it is a good idea, I used the same idea(ish)to ballast the little Kilo....the beauty of it is that you can remove it if you get it wrong.
      Current date/time is Thu Nov 21, 2024 10:01 am
