In total there are 6 users online :: 0 Registered, 0 Hidden and 6 Guests :: 1 Bot
Our users have posted a total of 12531 messages in 1991 subjects
We have 1019 registered users
8 posters
CSS PIONEER
- Post n°126
Re: CSS PIONEER
Looking really good, Nigel!
- Post n°127
CSS PIONEER
[url=https://servimg.com/view/16856337/105][/url,]
This is the mould for the rubbing strip, I doubt that the boat was fitted with them, although some drawings I have seen do show them, but I have decided to fit them anyway. If nothing else it saves a lot of effort cleaning up the mould joints as these can be fitted over them.
- Post n°128
Re: CSS PIONEER
Rubbing strips fitted, bonded to the hull with gel coat.
- Post n°129
Re: CSS PIONEER
Another view with the rubbing strips in place.
- Post n°130
Re: CSS PIONEER
And another view of rubbing strips.
- Post n°131
Re: CSS PIONEER
Patter n for prop guard, again there is some debate as to whether or not the boat was fitted with one. I have come to the conclusion that it probably was, reason's beng that some acounts state that it was fitted with a towed charge, that being the case the tow line would likely end up being fouled by the prop. It would also seem logical as the Hunley was fitted with a prop guard, and the Hunley was a development of this boat, anyway that's my story and I'm sticking to it...officer.
- Post n°132
Re: CSS PIONEER
Another view of the prop guard pattern.
- Post n°133
Re: CSS PIONEER
Mould for the prop guard, with gel and tissue applied.
- Post n°134
Re: CSS PIONEER
Another view of the prop guard mould being made.
- Post n°135
Re: CSS PIONEER
Veiw of prop guard, needs trimming.
- Post n°136
Re: CSS PIONEER
Another view of prop guard, it's very thin, I'm not sure if it will be strong enough. It's 1x tissue and 1x300 gsm.
- Post n°137
CSS PIONEER
This is the mould for the keel, its a 9inch x 2inch block of MDF covered in alloy foil glued to a piece of plywood which is also covered in foil, it has shuttering down the centre as previously shown when doing the main hull.
- Post n°138
Re: CSS PIONEER
One half of the plug PVA'ed, allowed to dry and then gel applied,this is the same method previously used on the main hull.
- Post n°139
Re: CSS PIONEER
The finished mould with the first keel ready to be removed, same lay up as main hull, 1x tissue 2x300gsm.
- Post n°140
Re: CSS PIONEER
Another view of the first keel in the mould.
- Post n°141
Re: CSS PIONEER
The keel,prop guard,and rubbing strips,after being trimmed up.
- Post n°142
Re: CSS PIONEER
Another view of the trimmed parts.
- Post n°143
Re: CSS PIONEER
This is the pattern for the mounting for the explosive charge, this is made from alloy sheet detailed with rivets as previously described, note the raised edges...this is achieved by cutting thin strips of alloy foil and placing them along the edges, before covering the whole thing in foil, again it is on a plywood backer.
- Post n°144
Re: CSS PIONEER
Anoter view of the pattern, this is a one piece mould.
- Post n°145
Re: CSS PIONEER
The finished mould,1x tissue,1x300 2x450 layup.
- Post n°146
Re: CSS PIONEER
Very nice work!
Giovanni LiCalsi- Guest
- Post n°147
Re: CSS PIONEER
Nigele,
Brilliant build.
How do you get such a perfect shape on the tapered metal bands on the ends of the hull?
Brilliant build.
- Post n°148
Re: CSS PIONEER
Hi Giovanni
I am not sure what you mean could you explain a litle more,many thanks
Nigel.
Nigel.
- Post n°149
Re: CSS PIONEER
I would like to build this in oxygen-free copper sheet and was wondering how to get a tapered band made without a lot of waste.
Possibly use paper card stock as a template ?
- Post n°150
Re: CSS PIONEER
Hi Giovanni,
sorry for delay I have been thinking about your question,can you give me some idea of the size you intend to make the hull,and are you going to use a core to wrap the copper round,this hull has overlapping plate's so it will require a lot of copper as you will need to make two cones instead of the one you would need if the plates where butted up.
regards nigel.
regards nigel.
