To BEC...or not to BEC? EmptyYesterday at 4:46 pm by tsenecal
To BEC...or not to BEC? EmptySun Oct 20, 2024 2:04 pm by geofrancis
To BEC...or not to BEC? EmptyThu Oct 17, 2024 2:34 pm by geofrancis
To BEC...or not to BEC? EmptyMon Oct 14, 2024 4:31 pm by geofrancis
To BEC...or not to BEC? EmptySat Oct 12, 2024 3:52 pm by geofrancis
To BEC...or not to BEC? EmptyFri Oct 11, 2024 8:58 pm by Marylandradiosailor
To BEC...or not to BEC? EmptyFri Oct 11, 2024 8:14 pm by geofrancis
To BEC...or not to BEC? EmptyThu Oct 10, 2024 3:21 am by tsenecal
To BEC...or not to BEC? EmptyWed Oct 02, 2024 11:32 am by geofrancis
    To BEC...or not to BEC? Empty To BEC...or not to BEC?
    Post  Tom(ADMIN) Thu Nov 17, 2011 6:44 pm
    What do you guys think of using a BEC on your radio installations?
    I've used them before on surface boats and had the main battery drop down enough to cut the power to the radio...result, a stranded boat. In a sub that could mean a sub down on the bottom with not enough power to get up again, I guess.
    My new submersible will be a dynamic dive boat to start with, so the problem isn't quite that bad, but I do plan to fit a pump and bag later, that's when the problems could arise.
    So, what do you think...fit an extra battery pack for the rx? Or go with the BEC?
    To BEC...or not to BEC? Empty Re: To BEC...or not to BEC?
    Post  david f Fri Nov 18, 2011 1:05 pm
    I wouldn't go with a separate RX battery, Richard.
    I think that Norbert Bruggen put it well in his book. The chances are doubled that one of the batteries will fail.
    Best go with a BEC in my view.
    Actually I now go with a separate switch mode "BEC". Running on 12v I find that the normal BEC overheats and you go into shutdown every few seconds. Most disconcerting!
    Post  Hermann Tue Nov 22, 2011 7:52 pm
    Hello,
    I am also a supporter of a central power source design that delivers the power for all the systems on board and I have made good experience with it over the years.
    For receiver and servo supply and vor other low voltage/ power consumers I use some switchmode step-down converters of own design in my models to reduce the main battery voltage (12V or 14.4V) to an intermediate voltage of 6V with linear low-drop post regulators following for each supply path (one for receiver, one for servos ...). Of course the switchmode converters need a good EMI suppression but this is no problem you can't solve.
    Best regards
    Post  david f Wed Nov 23, 2011 3:24 pm
    Hi Hermann,
    Yes, I suppose I have had reasonable experiences with switch mode supply. But we have been having an interesting discussion on another Forum (Model Boat Mayhem - Sorry Richard!) with John who suggests that they cause RF interference.
    I realised from this that I have had a problem with this - solved by switching to dual band conversion receivers.
    So my confidence in recommending switch mode power supplies has taken a slight knock but I still think that the BEC principle is the best one.
    Post  Tom(ADMIN) Wed Nov 23, 2011 3:32 pm
    We shall soon find out, I've gone for an Mtroniks Viper esc with built BEC, and I'll use a Corona rx, I think...I have plenty of them.
      Current date/time is Wed Oct 30, 2024 10:51 am
