I have a problem with the ESC - I have posted this in the electronics section. Basically all the lights flash as they should but the motors will not reverse...
Both ESCs are the same. I have enabled & disabled reverse which is easy to do - no joy. I have tried a range of options - the fault is not with the transmitter as the issue persists on every channel.
Odd - could be the ESCs are both broken but as both are the same & forward works perfectly I think it is something basic I just cannot see- I have emailed Engel for advice.
I just wonder if anyone else has had this problem,
ATB
ROb
