All-Metal 1/12TH Scale USS Holland Submarine 14212712
In total there are 34 users online :: 0 Registered, 0 Hidden and 34 Guests :: 1 Bot
All-Metal 1/12TH Scale USS Holland Submarine EmptyTue Oct 29, 2024 4:46 pm by tsenecal
All-Metal 1/12TH Scale USS Holland Submarine EmptySun Oct 20, 2024 2:04 pm by geofrancis
All-Metal 1/12TH Scale USS Holland Submarine EmptyThu Oct 17, 2024 2:34 pm by geofrancis
All-Metal 1/12TH Scale USS Holland Submarine EmptyMon Oct 14, 2024 4:31 pm by geofrancis
All-Metal 1/12TH Scale USS Holland Submarine EmptySat Oct 12, 2024 3:52 pm by geofrancis
All-Metal 1/12TH Scale USS Holland Submarine EmptyFri Oct 11, 2024 8:58 pm by Marylandradiosailor
All-Metal 1/12TH Scale USS Holland Submarine EmptyFri Oct 11, 2024 8:14 pm by geofrancis
All-Metal 1/12TH Scale USS Holland Submarine EmptyThu Oct 10, 2024 3:21 am by tsenecal
All-Metal 1/12TH Scale USS Holland Submarine EmptyWed Oct 02, 2024 11:32 am by geofrancis
    All-Metal 1/12TH Scale USS Holland Submarine Empty All-Metal 1/12TH Scale USS Holland Submarine
    Post  Giovanni LiCalsi Mon Nov 15, 2010 10:50 pm
    Hello members,
    I have been working on the design and building methods for the USS Holland for about 2 years now and finally starting to machine parts.
    The hull will be metal spun out of 260 casing brass and all of the fittings will be lost-wax cast in 342 brass.
    I have all of the cad drawings required to produce all of the parts to factory specifications.
    I am building 6 kits and 3 are already spoken for.
    This is not a profiting project but a labor of love.
    I am also designing a Jules Verne style amphibious steam-propelled screw-drive vehicle.
    I am posting some images and any constructive advice is very welcome.
    Thanks,
    Giovanni
    1929 Fordson Snow-Mobile
    https://www.youtube.com/watch?v=zBjlSJf4274
    All-Metal 1/12TH Scale USS Holland Submarine Ss1boxart1ea0
    All-Metal 1/12TH Scale USS Holland Submarine Ss1v4r3psob5
    All-Metal 1/12TH Scale USS Holland Submarine Ss1v3lt5
    All-Metal 1/12TH Scale USS Holland Submarine Plnsrdrscrewfd0
    All-Metal 1/12TH Scale USS Holland Submarine PortCutaway
    Vinniesketchbook
    All-Metal 1/12TH Scale USS Holland Submarine Empty WOW..
    Post  Vinniesketchbook Thu May 17, 2012 1:12 am
    i'm so envious of your model
    I started to model in CAD the prototype holland about 18 months ago but ran out of info. had to invent a lot based on contemporary motors etc.. where did you get all the detail to work from?
    All-Metal 1/12TH Scale USS Holland Submarine Empty Re: All-Metal 1/12TH Scale USS Holland Submarine
    Post  Giovanni LiCalsi Thu May 17, 2012 2:00 am
    Hi Vinnie,
    I was very fortunate to be associated with Gary McCue, the USS Holland historian.
    He works with General Dynamics and is a software specialist.
    I was able to get many original drawings and photos of the Holland from him.
    I have a very large archive now.
    I have decided to build the main hull out of hardened aluminum.
    It will be metal spun from 6161 aluminum sheet in 4 sections and then tig welded together.
    The rest of the parts will be made as previously planned.
    This will make the submarine much lighter and easier to launch at the pool.
    The hull will be anodized in a black finish.
    The hull will be installed in a rotating fixture and the bottom access hatch will be laser cut, along with the other openings on the hull.
    The inside of the hatch will be laser printed with the model serial number and I.D.
    and the hull flush rivets and hull sheet seams will be laser printed, as well.
    I have all of the cad drawings to have this done.
    The previous drawing here has the incorrect hull seams. They are longitudel.
      Current date/time is Thu Nov 21, 2024 9:04 am
