In total there are 22 users online :: 0 Registered, 0 Hidden and 22 Guests :: 1 Bot
Our users have posted a total of 12481 messages in 1987 subjects
We have 1019 registered users
Dr.Schmidt
9 posters
Germany's first military submarine, the S.M. U-1
Outstanding workmanship...I am very jealous!
profesorul- Guest
HI,
ANDREEAS
You did an amazing job until know.
Are You SHORE these is Your first SUB!?.
Because if these is the first sub of you , I can only imagine how wheel be the next one.
Absolutely beautiful job.
Please Keep as on post with everything You do.
REGARDS MARIUS
ANDREEAS
REGARDS MARIUS
Dr.Schmidt- Guest
I built twi subs from kits when I was 18. Didn't work out really. So now 21 years later this is the first submarine I build from scratch, starting with the design, building the molds, making the parts etc.....but I have some skills from building RC planes and I have an engineering background.
So I have a baisc idea how it should work, but this is the first one that I'll have designed and built on my own.
Cheers Andeas
P.S.
I also make slow but steady progress. Here's the pressure tight compartment in the lower hull:
![Germany's first military submarine, the S.M. U-1 - Page 2 DSC01431_zps2ac1555f](https://2img.net/h/i1262.photobucket.com/albums/ii604/MaschinenMusik/Modelsubmarine%20SM%20U-1/DSC01431_zps2ac1555f.jpg)
Cheers Andeas
P.S.
Dr.Schmidt- Guest
After a longer break, I can report progress again. The struts to hold the pressure tube are installed, the screw points for the pressure tube are in place, the drive shafts are installed and the front servo compartment is secured. Looks like a true two-hull sub.....
![Germany's first military submarine, the S.M. U-1 - Page 2 DSC01630_zpsc201f6aa](https://2img.net/h/i1262.photobucket.com/albums/ii604/MaschinenMusik/Modelsubmarine%20SM%20U-1/DSC01630_zpsc201f6aa.jpg)
![Germany's first military submarine, the S.M. U-1 - Page 2 DSC01632_zps161fe73d](https://2img.net/h/i1262.photobucket.com/albums/ii604/MaschinenMusik/Modelsubmarine%20SM%20U-1/DSC01632_zps161fe73d.jpg)
![Germany's first military submarine, the S.M. U-1 - Page 2 DSC01633_zps19bfb093](https://2img.net/h/i1262.photobucket.com/albums/ii604/MaschinenMusik/Modelsubmarine%20SM%20U-1/DSC01633_zps19bfb093.jpg)
![Germany's first military submarine, the S.M. U-1 - Page 2 DSC01634_zpsdc7edccd](https://2img.net/h/i1262.photobucket.com/albums/ii604/MaschinenMusik/Modelsubmarine%20SM%20U-1/DSC01634_zpsdc7edccd.jpg)
Dr.Schmidt- Guest
And again some progress. The hydroplanes and the stabilization fins are installed. The mechanics for the rear hydroplanes is somewhat complicated, as the hydroplanes are too close to the pressure tight compartment to be directly connected to the push rods and the propeller axis prohibit a straight hydroplane axis. So everything is controlled via a second axis....the connection for the rudder is installed as well:
![Germany's first military submarine, the S.M. U-1 - Page 2 DSC01660_zpsdf2dbad9](https://2img.net/h/i1262.photobucket.com/albums/ii604/MaschinenMusik/Modelsubmarine%20SM%20U-1/DSC01660_zpsdf2dbad9.jpg)
![Germany's first military submarine, the S.M. U-1 - Page 2 DSC01670_zps17533d56](https://2img.net/h/i1262.photobucket.com/albums/ii604/MaschinenMusik/Modelsubmarine%20SM%20U-1/DSC01670_zps17533d56.jpg)
Allot of work as well, the water inlets in the upper hull. I didn't just want to file some, so I fabricated frames from pu-resin and glued them into slits in the upper hull, filled everything and sanded it down flush to the hull's outer surface.
![Germany's first military submarine, the S.M. U-1 - Page 2 DSC01662_zps3e7119ec](https://2img.net/h/i1262.photobucket.com/albums/ii604/MaschinenMusik/Modelsubmarine%20SM%20U-1/DSC01662_zps3e7119ec.jpg)
Similar business are the snorkel housings. Got the rapid prototyped and then glued them to the underside of the deck. After that the open parts in the deck were milled and filed away. Front:
![Germany's first military submarine, the S.M. U-1 - Page 2 2e0984a5-68ce-43ab-883a-2f808f40b119_zpsf583eea4](https://2img.net/h/i1262.photobucket.com/albums/ii604/MaschinenMusik/Modelsubmarine%20SM%20U-1/2e0984a5-68ce-43ab-883a-2f808f40b119_zpsf583eea4.jpg)
and rear:
![Germany's first military submarine, the S.M. U-1 - Page 2 DSC01665_zps1ef4289c](https://2img.net/h/i1262.photobucket.com/albums/ii604/MaschinenMusik/Modelsubmarine%20SM%20U-1/DSC01665_zps1ef4289c.jpg)
Same thing from the inside - rear:
![Germany's first military submarine, the S.M. U-1 - Page 2 DSC01666_zpsf4d6d477](https://2img.net/h/i1262.photobucket.com/albums/ii604/MaschinenMusik/Modelsubmarine%20SM%20U-1/DSC01666_zpsf4d6d477.jpg)
Front:
![Germany's first military submarine, the S.M. U-1 - Page 2 DSC01668_zps87fc4380](https://2img.net/h/i1262.photobucket.com/albums/ii604/MaschinenMusik/Modelsubmarine%20SM%20U-1/DSC01668_zps87fc4380.jpg)
And again the water inlet frames in detail:
![Germany's first military submarine, the S.M. U-1 - Page 2 DSC01669_zpsc57e2a76](https://2img.net/h/i1262.photobucket.com/albums/ii604/MaschinenMusik/Modelsubmarine%20SM%20U-1/DSC01669_zpsc57e2a76.jpg)
and rear:
Front:
Dr.Schmidt- Guest
O.K., againe some progress....
The lower hull got its base coat, was sanded to a good finish and now it gets its rivets. Latter are surface detail decals from Archer Fine Tranfers aufbringe. Slow, not cheap, but it looks good:
Bow with torpedo hatch:
![Germany's first military submarine, the S.M. U-1 - Page 2 IMGP0102_zpse784df25](https://2img.net/h/i1262.photobucket.com/albums/ii604/MaschinenMusik/Modelsubmarine%20SM%20U-1/IMGP0102_zpse784df25.jpg)
middship:
![Germany's first military submarine, the S.M. U-1 - Page 2 IMGP0105_zpsb698c3cb](https://2img.net/h/i1262.photobucket.com/albums/ii604/MaschinenMusik/Modelsubmarine%20SM%20U-1/IMGP0105_zpsb698c3cb.jpg)
stern:
![Germany's first military submarine, the S.M. U-1 - Page 2 IMGP0108_zpsa5c42709](https://2img.net/h/i1262.photobucket.com/albums/ii604/MaschinenMusik/Modelsubmarine%20SM%20U-1/IMGP0108_zpsa5c42709.jpg)
The tower also got its base coat and is ready to be painted:
![Germany's first military submarine, the S.M. U-1 - Page 2 IMGP0111_zpse5e33ad7](https://2img.net/h/i1262.photobucket.com/albums/ii604/MaschinenMusik/Modelsubmarine%20SM%20U-1/IMGP0111_zpse5e33ad7.jpg)
![Germany's first military submarine, the S.M. U-1 - Page 2 IMGP0112_zps51187ef5](https://2img.net/h/i1262.photobucket.com/albums/ii604/MaschinenMusik/Modelsubmarine%20SM%20U-1/IMGP0112_zps51187ef5.jpg)
middship:
stern:
Very nice work indeed, sir...those rivets look really good, much easier than applying drops of glue by hand.
Dr.Schmidt- Guest
And the dimensions become much more scale than glue droplets....
Dr.Schmidt- Guest
Lower hull is painted in RAL7016. Turned out good and the rivets look nice....
![Germany's first military submarine, the S.M. U-1 - Page 2 DSC01746_zps3377a637](https://2img.net/h/i1262.photobucket.com/albums/ii604/MaschinenMusik/Modelsubmarine%20SM%20U-1/DSC01746_zps3377a637.jpg)
![Germany's first military submarine, the S.M. U-1 - Page 2 DSC01747_zps5c9caa42](https://2img.net/h/i1262.photobucket.com/albums/ii604/MaschinenMusik/Modelsubmarine%20SM%20U-1/DSC01747_zps5c9caa42.jpg)
![Germany's first military submarine, the S.M. U-1 - Page 2 DSC01750_zps9191c47a](https://2img.net/h/i1262.photobucket.com/albums/ii604/MaschinenMusik/Modelsubmarine%20SM%20U-1/DSC01750_zps9191c47a.jpg)
![Germany's first military submarine, the S.M. U-1 - Page 2 DSC01749_zps0eda7546](https://2img.net/h/i1262.photobucket.com/albums/ii604/MaschinenMusik/Modelsubmarine%20SM%20U-1/DSC01749_zps0eda7546.jpg)
![Germany's first military submarine, the S.M. U-1 - Page 2 DSC01748_zpsc1f0f014](https://2img.net/h/i1262.photobucket.com/albums/ii604/MaschinenMusik/Modelsubmarine%20SM%20U-1/DSC01748_zpsc1f0f014.jpg)
![Germany's first military submarine, the S.M. U-1 - Page 2 DSC01752_zps60e4d2b3](https://2img.net/h/i1262.photobucket.com/albums/ii604/MaschinenMusik/Modelsubmarine%20SM%20U-1/DSC01752_zps60e4d2b3.jpg)
![Germany's first military submarine, the S.M. U-1 - Page 2 DSC01751_zpse40ab035](https://2img.net/h/i1262.photobucket.com/albums/ii604/MaschinenMusik/Modelsubmarine%20SM%20U-1/DSC01751_zpse40ab035.jpg)
Superb work, sir...absolutely superb. My congratulations...
Giovanni LiCalsi- Guest
Beautiful craftsmanship!
Dr.Schmidt- Guest
O.K., I have a few weeks of filling, grinding, applying details and rivets and cleaning behind me, and yesterday we finally could paint the upper hull in RAL7001. Here are the first impressions. I'm rather pleased.
![Germany's first military submarine, the S.M. U-1 - Page 2 DSC01759_zps329944b8](https://2img.net/h/i1262.photobucket.com/albums/ii604/MaschinenMusik/Modelsubmarine%20SM%20U-1/DSC01759_zps329944b8.jpg)
![Germany's first military submarine, the S.M. U-1 - Page 2 DSC01760_zps41847e4e](https://2img.net/h/i1262.photobucket.com/albums/ii604/MaschinenMusik/Modelsubmarine%20SM%20U-1/DSC01760_zps41847e4e.jpg)
![Germany's first military submarine, the S.M. U-1 - Page 2 DSC01761_zps845c1226](https://2img.net/h/i1262.photobucket.com/albums/ii604/MaschinenMusik/Modelsubmarine%20SM%20U-1/DSC01761_zps845c1226.jpg)
![Germany's first military submarine, the S.M. U-1 - Page 2 DSC01762_zpse9501ccd](https://2img.net/h/i1262.photobucket.com/albums/ii604/MaschinenMusik/Modelsubmarine%20SM%20U-1/DSC01762_zpse9501ccd.jpg)
![Germany's first military submarine, the S.M. U-1 - Page 2 DSC01763_zpsfa41e953](https://2img.net/h/i1262.photobucket.com/albums/ii604/MaschinenMusik/Modelsubmarine%20SM%20U-1/DSC01763_zpsfa41e953.jpg)
![Germany's first military submarine, the S.M. U-1 - Page 2 DSC01764_zpse46b80f6](https://2img.net/h/i1262.photobucket.com/albums/ii604/MaschinenMusik/Modelsubmarine%20SM%20U-1/DSC01764_zpse46b80f6.jpg)
![Germany's first military submarine, the S.M. U-1 - Page 2 DSC01765_zps12988489](https://2img.net/h/i1262.photobucket.com/albums/ii604/MaschinenMusik/Modelsubmarine%20SM%20U-1/DSC01765_zps12988489.jpg)
![Germany's first military submarine, the S.M. U-1 - Page 2 DSC01767_zps1d26ce08](https://2img.net/h/i1262.photobucket.com/albums/ii604/MaschinenMusik/Modelsubmarine%20SM%20U-1/DSC01767_zps1d26ce08.jpg)
![Germany's first military submarine, the S.M. U-1 - Page 2 DSC01768_zps5c46b640](https://2img.net/h/i1262.photobucket.com/albums/ii604/MaschinenMusik/Modelsubmarine%20SM%20U-1/DSC01768_zps5c46b640.jpg)
![Germany's first military submarine, the S.M. U-1 - Page 2 DSC01769_zps253219c7](https://2img.net/h/i1262.photobucket.com/albums/ii604/MaschinenMusik/Modelsubmarine%20SM%20U-1/DSC01769_zps253219c7.jpg)
![Germany's first military submarine, the S.M. U-1 - Page 2 DSC01771_zpsd52b449a](https://2img.net/h/i1262.photobucket.com/albums/ii604/MaschinenMusik/Modelsubmarine%20SM%20U-1/DSC01771_zpsd52b449a.jpg)
![Germany's first military submarine, the S.M. U-1 - Page 2 DSC01772_zpsc73a8a01](https://2img.net/h/i1262.photobucket.com/albums/ii604/MaschinenMusik/Modelsubmarine%20SM%20U-1/DSC01772_zpsc73a8a01.jpg)
And of course we have to look at the assembly as well........puts a smile on my face :D
![Germany's first military submarine, the S.M. U-1 - Page 2 DSC01776_zpse16d49fb](https://2img.net/h/i1262.photobucket.com/albums/ii604/MaschinenMusik/Modelsubmarine%20SM%20U-1/DSC01776_zpse16d49fb.jpg)
That looks lovely!
Dr.Schmidt- Guest
O.K., spent two weeks with filters and washings to weather the upper hull. I did a subtle job and on the photos it looks even more subtle. I'm not a big fan of weatherings that look like the bot got sunk five times. I hope the washings and filters will go well together with the acrylic clear coat I'm going to apply next. Well, we'll see. Next is the weathering of the lower hull. As it is les detailed, it should be a quicker job than the upper hull.
![Germany's first military submarine, the S.M. U-1 - Page 2 DSC01779_zps2ce50fbf](https://2img.net/h/i1262.photobucket.com/albums/ii604/MaschinenMusik/Modelsubmarine%20SM%20U-1/DSC01779_zps2ce50fbf.jpg)
![Germany's first military submarine, the S.M. U-1 - Page 2 DSC01780_zpsd3e28e96](https://2img.net/h/i1262.photobucket.com/albums/ii604/MaschinenMusik/Modelsubmarine%20SM%20U-1/DSC01780_zpsd3e28e96.jpg)
![Germany's first military submarine, the S.M. U-1 - Page 2 DSC01781_zpsf1d5c2ca](https://2img.net/h/i1262.photobucket.com/albums/ii604/MaschinenMusik/Modelsubmarine%20SM%20U-1/DSC01781_zpsf1d5c2ca.jpg)
![Germany's first military submarine, the S.M. U-1 - Page 2 DSC01782_zpseec0e56d](https://2img.net/h/i1262.photobucket.com/albums/ii604/MaschinenMusik/Modelsubmarine%20SM%20U-1/DSC01782_zpseec0e56d.jpg)
![Germany's first military submarine, the S.M. U-1 - Page 2 DSC01784_zpsb7a1a189](https://2img.net/h/i1262.photobucket.com/albums/ii604/MaschinenMusik/Modelsubmarine%20SM%20U-1/DSC01784_zpsb7a1a189.jpg)
![Germany's first military submarine, the S.M. U-1 - Page 2 DSC01786_zpsc821e9a7](https://2img.net/h/i1262.photobucket.com/albums/ii604/MaschinenMusik/Modelsubmarine%20SM%20U-1/DSC01786_zpsc821e9a7.jpg)
Came out VERY nice!
profesorul- Guest
ABSOLUTELY SUPERB WORK . CONGRATULATION and PLEASE Don't stop here .
P.S. What happened to the FORUM ?!
Dr.Schmidt- Guest
And on we go.....the machine frame is ready.Here some pictures. Just the receiver, gaskets and bellows, and then I can check if everything is watertight.
![Germany's first military submarine, the S.M. U-1 - Page 2 DSC01793_zpsb67723f7](https://2img.net/h/i1262.photobucket.com/albums/ii604/MaschinenMusik/Modelsubmarine%20SM%20U-1/DSC01793_zpsb67723f7.jpg)
![Germany's first military submarine, the S.M. U-1 - Page 2 DSC01796_zps8fe1817c](https://2img.net/h/i1262.photobucket.com/albums/ii604/MaschinenMusik/Modelsubmarine%20SM%20U-1/DSC01796_zps8fe1817c.jpg)
![Germany's first military submarine, the S.M. U-1 - Page 2 DSC01791_zps5376f4f5](https://2img.net/h/i1262.photobucket.com/albums/ii604/MaschinenMusik/Modelsubmarine%20SM%20U-1/DSC01791_zps5376f4f5.jpg)
![Germany's first military submarine, the S.M. U-1 - Page 2 DSC01792_zps947559fd](https://2img.net/h/i1262.photobucket.com/albums/ii604/MaschinenMusik/Modelsubmarine%20SM%20U-1/DSC01792_zps947559fd.jpg)
Also additional work on the upper hull. Finished the mechanics to extend the snorkels and the chain drive of the upper rudder. The snorkels are actuated via a Firgelli linear servo which is located in an watertight compartment below the conning tower.
![Germany's first military submarine, the S.M. U-1 - Page 2 DSC01797_zps3e5e346d](https://2img.net/h/i1262.photobucket.com/albums/ii604/MaschinenMusik/Modelsubmarine%20SM%20U-1/DSC01797_zps3e5e346d.jpg)
![Germany's first military submarine, the S.M. U-1 - Page 2 DSC01799_zps137448ad](https://2img.net/h/i1262.photobucket.com/albums/ii604/MaschinenMusik/Modelsubmarine%20SM%20U-1/DSC01799_zps137448ad.jpg)
![Germany's first military submarine, the S.M. U-1 - Page 2 DSC01800_zps0e9c8032](https://2img.net/h/i1262.photobucket.com/albums/ii604/MaschinenMusik/Modelsubmarine%20SM%20U-1/DSC01800_zps0e9c8032.jpg)
![Germany's first military submarine, the S.M. U-1 - Page 2 DSC01801_zps5101db07](https://2img.net/h/i1262.photobucket.com/albums/ii604/MaschinenMusik/Modelsubmarine%20SM%20U-1/DSC01801_zps5101db07.jpg)
Dr.Schmidt- Guest
Well, the submarine test pool has been installed :D
![Germany's first military submarine, the S.M. U-1 - Page 2 05072014042_zpsd70e1185](https://2img.net/h/i1262.photobucket.com/albums/ii604/MaschinenMusik/Modelsubmarine%20SM%20U-1/05072014042_zpsd70e1185.jpg)
And the first tests of the WTC have been performed. So far everything works fine. Tomorrow I'll conduct a harder test program.....
![Germany's first military submarine, the S.M. U-1 - Page 2 05072014043_zps292f4503](https://2img.net/h/i1262.photobucket.com/albums/ii604/MaschinenMusik/Modelsubmarine%20SM%20U-1/05072014043_zps292f4503.jpg)
Really nice! I'm even impressed by your test tank!
Dr.Schmidt- Guest
Works a treat for 65€...
Dr.Schmidt- Guest
O.K.: The boat is almost ready. Only some ropes are missing, but for handling reasons those will be added later. Next is the balancing of the boat. So here some photos:
![Germany's first military submarine, the S.M. U-1 - Page 2 DSC01804_zps7caa21f1](https://2img.net/h/i1262.photobucket.com/albums/ii604/MaschinenMusik/Modelsubmarine%20SM%20U-1/DSC01804_zps7caa21f1.jpg)
![Germany's first military submarine, the S.M. U-1 - Page 2 DSC01805_zpsa61188e3](https://2img.net/h/i1262.photobucket.com/albums/ii604/MaschinenMusik/Modelsubmarine%20SM%20U-1/DSC01805_zpsa61188e3.jpg)
The upper rudder is driven by the main rudder and thereby also drives the push rods and chain drives that used to actuate the rudder in the original:
![Germany's first military submarine, the S.M. U-1 - Page 2 DSC01806_zps9a767040](https://2img.net/h/i1262.photobucket.com/albums/ii604/MaschinenMusik/Modelsubmarine%20SM%20U-1/DSC01806_zps9a767040.jpg)
The snorkels can be extended and retracted by a linear servo:
![Germany's first military submarine, the S.M. U-1 - Page 2 DSC01807_zpsf6fed298](https://2img.net/h/i1262.photobucket.com/albums/ii604/MaschinenMusik/Modelsubmarine%20SM%20U-1/DSC01807_zpsf6fed298.jpg)
![Germany's first military submarine, the S.M. U-1 - Page 2 DSC01811_zps98ab3d1a](https://2img.net/h/i1262.photobucket.com/albums/ii604/MaschinenMusik/Modelsubmarine%20SM%20U-1/DSC01811_zps98ab3d1a.jpg)
![Germany's first military submarine, the S.M. U-1 - Page 2 DSC01812_zps5469e166](https://2img.net/h/i1262.photobucket.com/albums/ii604/MaschinenMusik/Modelsubmarine%20SM%20U-1/DSC01812_zps5469e166.jpg)
![Germany's first military submarine, the S.M. U-1 - Page 2 DSC01813_zps3a3cadc9](https://2img.net/h/i1262.photobucket.com/albums/ii604/MaschinenMusik/Modelsubmarine%20SM%20U-1/DSC01813_zps3a3cadc9.jpg)
![Germany's first military submarine, the S.M. U-1 - Page 2 DSC01814_zps2612ddef](https://2img.net/h/i1262.photobucket.com/albums/ii604/MaschinenMusik/Modelsubmarine%20SM%20U-1/DSC01814_zps2612ddef.jpg)
![Germany's first military submarine, the S.M. U-1 - Page 2 DSC01816_zps15fec88b](https://2img.net/h/i1262.photobucket.com/albums/ii604/MaschinenMusik/Modelsubmarine%20SM%20U-1/DSC01816_zps15fec88b.jpg)
Very nice!
It is interesting to see how smooth and uncluttered the original design was. The clutter came later before the British R class and the German Type XXI cleared it away again.
Dr.Schmidt- Guest
That's one of the reasons I wanted to build the modell. The U-1 was a real nice and smooth design. Very elegant.
Dr.Schmidt- Guest
Adding buoyancy via pu foam did the Job. First time the boat floats on even keel and at the right water line.
![Germany's first military submarine, the S.M. U-1 - Page 2 04082014050_zps44e7ebd2](https://2img.net/h/i1262.photobucket.com/albums/ii604/MaschinenMusik/Modelsubmarine%20SM%20U-1/04082014050_zps44e7ebd2.jpg)
Dr.Schmidt- Guest
Click to see the video!
The snorkels are working and the AMP Superseal connector works, too. The boat dives reliably and can sensitively be trimmed using the proportional tank control of the Engel tanks. Some minor adjustments and then I have to answer a question that I had pushed away since now.....where to do the first real test run.
» David Forrest's R class
» bladder bags
