In total there are 22 users online :: 0 Registered, 0 Hidden and 22 Guests :: 2 Bots
WTC's and radio boxes
Topics | Replies | Author | Views | Last Posts | ||
Sheerline gasket material | 0 | Michaelc | 537 | Mon Feb 19, 2024 9:24 pm by Michaelc | ||
GRP end caps | 2 | SimonH | 1307 | Tue Sep 28, 2021 4:17 pm by janttu | ||
The SubDriver becomes Modular | 20 | merriman | 2975 | Fri Jan 24, 2020 12:05 am by merriman | ||
gear-splitter | 0 | merriman | 961 | Sun Dec 01, 2019 8:16 am by merriman | ||
brushed motors i have 3 brushed motors do they need sealing | 1 | chesh111 | 1543 | Mon Oct 22, 2018 11:47 am by merriman | ||
small diameter static-diving type SubDriver | 12 | merriman | 3007 | Sun Jul 15, 2018 11:30 am by merriman | ||
"Made to measure" dive systems | 8 | dgp1957 | 2603 | Tue May 01, 2018 12:08 pm by dgp1957 | ||
[ Poll ] WTC Material Acrylic, policarbonate or clear pvc | 1 | JuanGg | 1713 | Thu May 11, 2017 7:43 pm by merriman | ||
Can anyone identify the manufacturer | 0 | Jeff's | 1502 | Wed May 10, 2017 10:18 pm by Jeff's | ||
Ballast systems for 1/35 Bronco Type XXIII | 1 | Peter Webster | 2152 | Fri Jan 22, 2016 11:49 am by david f | ||
WTC End Caps Resin Caps | 6 | Radioman | 3637 | Thu Jul 30, 2015 12:48 am by Radioman | ||
D9 Engel Submarine Range problems | 7 | DAVE J | 2274 | Sun Feb 22, 2015 8:00 pm by DAVE J | ||
My first attempt at building a WTC Work in progress | 18 | Kevin D | 4798 | Thu Feb 19, 2015 5:38 pm by Kevin D | ||
Extra access hatch for Engel Type IX Want advice on thickness | 1 | Peter Webster | 1754 | Fri Nov 14, 2014 9:05 am by david f | ||
S class problem | 4 | dgp1957 | 2055 | Fri Oct 31, 2014 11:49 am by david f | ||
Push rods and prop shafts | 1 | Polycell | 2260 | Wed Apr 23, 2014 8:51 am by david f | ||
drilling acrylic tube pump suction | 0 | willte | 1804 | Fri Mar 21, 2014 6:31 pm by willte | ||
first attempt at end covers | 9 | willte | 2291 | Tue Feb 25, 2014 2:30 pm by willte | ||
Radio box repair | 4 | Tom(ADMIN) | 2267 | Thu Feb 20, 2014 8:10 pm by Tom(ADMIN) | ||
Wtc O ring set at Aldi 420 piece set sizes from 3.15 mm to 50mm | 1 | subdriver | 2021 | Thu Feb 06, 2014 8:03 pm by Tom(ADMIN) | ||
David Merriman... | 0 | Tom(ADMIN) | 2348 | Thu Dec 26, 2013 9:51 am by Tom(ADMIN) | ||
Two tier wtc? | 19 | Tom(ADMIN) | 3387 | Fri Dec 20, 2013 3:04 pm by Tom(ADMIN) | ||
WATER TIGHT COMPARTMENT ALUMINIUM | 11 | willte | 3315 | Mon Dec 16, 2013 3:01 pm by willte | ||
End cap problem... | 9 | Tom(ADMIN) | 2240 | Fri Dec 13, 2013 4:05 pm by merriman | ||
David Forrest.. | 2 | Tom(ADMIN) | 1839 | Mon Dec 02, 2013 9:33 am by Tom(ADMIN) | ||
Radio box.. | 1 | Tom(ADMIN) | 2003 | Fri Nov 22, 2013 9:15 am by Tom(ADMIN) | ||
Nigel... ? | 2 | Tom(ADMIN) | 1981 | Sat Oct 12, 2013 4:31 pm by Tom(ADMIN) | ||
Control rod seals.. | 3 | Tom(ADMIN) | 2946 | Sat Oct 05, 2013 10:23 am by Tom(ADMIN) | ||
Floating Ball Cutt off for Ballast Tank | 2 | timgarrod | 2006 | Sat Jul 27, 2013 10:52 am by timgarrod | ||
moebius seaview 1/28 scale. wtc needed for above. | 7 | wadsworthj | 3553 | Wed Jan 02, 2013 12:05 pm by Tom(ADMIN) | ||
alternate ballast system | 1 | klunk | 2425 | Fri Apr 06, 2012 4:38 pm by salmon | ||
robbe seawolf v.2. battery recharging. | 8 | wadsworthj | 3767 | Thu Mar 29, 2012 9:52 pm by johnrobinson | ||
Small water tight box | 8 | Simon 007 | 2782 | Sun Mar 04, 2012 7:10 pm by Simon 007 | ||
Rubber sheet | 0 | Tom(ADMIN) | 2692 | Tue Nov 29, 2011 8:52 am by Tom(ADMIN) | ||
X CRAFT X5 WTC. WTC FROM X5,NOW OWNED BY BILL MCLEOD. | 8 | nigele(ADMIN)2 | 2862 | Sun Nov 13, 2011 6:37 pm by kazzer | ||
Ballast bag | 2 | Nacken | 2472 | Wed Oct 12, 2011 7:03 am by Nacken | ||
Acrylc or Polycarbonate | 6 | salmon | 2306 | Mon Sep 12, 2011 3:36 pm by Giovanni LiCalsi | ||
WTC full length rods | 2 | Resolution Rog | 2705 | Fri Mar 18, 2011 2:44 pm by Resolution Rog | ||
Getting the hang of this now.. | 2 | Tom(ADMIN) | 2605 | Tue Dec 21, 2010 11:33 am by Tom(ADMIN) |
Sort
Users browsing this forum: 0 Registered, 0 Hidden and 1 Guest
Registered Users: None
