Push rods and prop shafts 14212712
In total there are 23 users online :: 0 Registered, 0 Hidden and 23 Guests :: 1 Bot
Push rods and prop shafts EmptyTue Oct 29, 2024 4:46 pm by tsenecal
Push rods and prop shafts EmptySun Oct 20, 2024 2:04 pm by geofrancis
Push rods and prop shafts EmptyThu Oct 17, 2024 2:34 pm by geofrancis
Push rods and prop shafts EmptyMon Oct 14, 2024 4:31 pm by geofrancis
Push rods and prop shafts EmptySat Oct 12, 2024 3:52 pm by geofrancis
Push rods and prop shafts EmptyFri Oct 11, 2024 8:58 pm by Marylandradiosailor
Push rods and prop shafts EmptyFri Oct 11, 2024 8:14 pm by geofrancis
Push rods and prop shafts EmptyThu Oct 10, 2024 3:21 am by tsenecal
Push rods and prop shafts EmptyWed Oct 02, 2024 11:32 am by geofrancis
    Polycell
    Push rods and prop shafts Empty Push rods and prop shafts
    Post  Polycell Mon Apr 21, 2014 12:38 pm
    OK Easter eggs found and eaten lets get on with this dive unit. Motor bracket built prop shafts loosely in place servo push rods again loosely in place so what and where are the best water tight push rods and prop shaft to be found. Bellows over seals for the push rods any advice welcome as to what to use and were in the UK can I buy such items
    Thanks
    Fred
    Push rods and prop shafts Empty Re: Push rods and prop shafts
    Post  david f Wed Apr 23, 2014 8:51 am
    The advice you have been given over on Model Boat Mayhem looks very solid.
    Plus if you search a little on here you will some suggested suppliers of bellows on ebay and also Simply Bearing for O rings, oil seals and bearings - a good supplier in my opinion.
    David F
      Current date/time is Thu Nov 21, 2024 8:42 am
