Alternative diving system 14212712
In total there are 11 users online :: 0 Registered, 0 Hidden and 11 Guests :: 1 Bot
Alternative diving system EmptyTue Oct 29, 2024 4:46 pm by tsenecal
Alternative diving system EmptySun Oct 20, 2024 2:04 pm by geofrancis
Alternative diving system EmptyThu Oct 17, 2024 2:34 pm by geofrancis
Alternative diving system EmptyMon Oct 14, 2024 4:31 pm by geofrancis
Alternative diving system EmptySat Oct 12, 2024 3:52 pm by geofrancis
Alternative diving system EmptyFri Oct 11, 2024 8:58 pm by Marylandradiosailor
Alternative diving system EmptyFri Oct 11, 2024 8:14 pm by geofrancis
Alternative diving system EmptyThu Oct 10, 2024 3:21 am by tsenecal
Alternative diving system EmptyWed Oct 02, 2024 11:32 am by geofrancis
    dgp1957
    Alternative diving system Empty Alternative diving system
    Post  dgp1957 Mon Jun 24, 2013 6:45 pm
    Hi my darnell sub has two aerosol cans mounted in the centre watertight are connected to a pump, would it be feasable to replace the cans with some sort of air bag system?
    Alternative diving system Empty Re: Alternative diving system
    Post  david f Tue Jun 25, 2013 7:03 pm
    Hi David,
    It would be helpful if you could give some more info.
    Is it an old model which you have bought? If so you may have someones take on the original Darnell system. (Air pumped from a reservoir (the cans?) into a bag.)
    My view is that the bag system is OK for smaller subs but you may wish to adopt the later Sheerline system (water pumped into a pressure vessel (the cans again??)
    If you have a look at the AMS website you will see a description of all the dive systems with their pros and cons.
    Post  david f Tue Jun 25, 2013 7:14 pm
    Actually I have just had a look at the website and the description of the pressure tank (Sheerline) system is not very clear. (I think a diagram is missing.)
    Is there any chance of fixing that, Richard?
    dgp1957
    Post  dgp1957 Tue Jun 25, 2013 7:57 pm
    Thanks David, the system as is stands just now is-
    There are two aerosol cans in the centre section of the sub. Thete are two holes in the hull inderneath the cans to allow water into the chamber when the compressor pumps the air from the flood space into the aerosol cans and a switch reverses the system blowing the air stored in the cans back into the space to force the water out.
    Thats how I think it works anyway lol
    Post  david f Wed Jun 26, 2013 4:30 pm
    Hi David,
    Sounds like you have a slightly modified Darnell.
    The compressor is perhaps out of a car pump? (The original Darnell used a small oscillating steam engine.)
    I don't think I would want to try to get that working. Water and compressors is an awkward and complex mixture.
    Again, I don't think you would go far wrong by using the pressure tank system as used by Sheerline. The only bits needed are a pressure tank (baffled to prevent sloshing and able to stand about 3 bars) a gear pump and a pinch valve on a servo. if you have  a good budget - go for an Engel piston tank.
    You will find lots of discussion and description of these items on this forum. The pressure tank is perhaps the most difficult item. I use home made ones (PVC pipe reinforced by glass fibre sheathing.) Sheerline do very nice stainless steel ones for a price!
    Maybe if you go to Norwich you can talk Chris of Sheerline into giving you just a tank for a reasonable sum?!
    The pump on the Sheerline website looks nice and is at a fair price. We have always liked the red plastic ones but they are not as well made as they used to be. (Talking to Chairman Nigel he thinks he has found a supplier of the original nice, French made ones.)
      Current date/time is Thu Nov 21, 2024 9:52 am
