Skipjack.part 2 - Page 3 14212712
In total there are 22 users online :: 0 Registered, 0 Hidden and 22 Guests :: 1 Bot
Skipjack.part 2 - Page 3 EmptyTue Oct 29, 2024 4:46 pm by tsenecal
Skipjack.part 2 - Page 3 EmptySun Oct 20, 2024 2:04 pm by geofrancis
Skipjack.part 2 - Page 3 EmptyThu Oct 17, 2024 2:34 pm by geofrancis
Skipjack.part 2 - Page 3 EmptyMon Oct 14, 2024 4:31 pm by geofrancis
Skipjack.part 2 - Page 3 EmptySat Oct 12, 2024 3:52 pm by geofrancis
Skipjack.part 2 - Page 3 EmptyFri Oct 11, 2024 8:58 pm by Marylandradiosailor
Skipjack.part 2 - Page 3 EmptyFri Oct 11, 2024 8:14 pm by geofrancis
Skipjack.part 2 - Page 3 EmptyThu Oct 10, 2024 3:21 am by tsenecal
Skipjack.part 2 - Page 3 EmptyWed Oct 02, 2024 11:32 am by geofrancis
sloop
timgarrod
gingyer
11 posters
    Skipjack.part 2
    Skipjack.part 2 - Page 3 Empty Re: Skipjack.part 2
    Post  Tom(ADMIN) Wed Aug 28, 2013 7:57 pm
    It makes life so much easier, Andy...saves all that bending of wire and making up parts to fit.
    After reading the "online how to do it", it took me about ten minutes to get these fitted and working properly. Next up are the top and bottom rudders.
    Post  salmon Wed Aug 28, 2013 8:15 pm
    Richard(Admin) wrote:It makes life so much easier, Andy...saves all that bending of wire and making up parts to fit.
    Richard,
    I really appreciate the work David has done on the fittings for the Skipjack. The quality is top notch and it has made my build go very quick. Keep up the great work there sir!
    Post  merriman Wed Aug 28, 2013 8:26 pm
    I should mention here that Tom has been a big help getting those instructions sorted out; to make them a bit more clear and useful. Thanks, Tom.
    Post  Tom(ADMIN) Wed Aug 28, 2013 8:26 pm
    Tell you what, Tom...the man is a master at this. I can't get over how easily everything fits...and fits first time.
    Post  Tom(ADMIN) Wed Aug 28, 2013 8:27 pm
    I didn't know that...thanks, Tom!
    Post  salmon Wed Aug 28, 2013 8:35 pm
    Thank you for the kind words.
    Post  Tom(ADMIN) Thu Aug 29, 2013 1:36 pm
    Day off building today, these dammed fingers are just not cooperating with me, so rather than cock things up, I decided to leave things alone for today.
    Post  Tom(ADMIN) Fri Aug 30, 2013 11:32 am
    The cylinder has just arrived from Nigel (thanks Nige..lovely job) fits perfectly and there's plenty of room to install everything.
    Skipjack.part 2 - Page 3 Photo_30
    Skipjack.part 2 - Page 3 Photo_31
    Post  Tom(ADMIN) Fri Aug 30, 2013 12:32 pm
    And here's the clever bit...note in the photos the small plastic lugs directly in front of the end caps. These are where the stand fits if you are building a static model...they are perfectly positioned to locate the cylinder and stop it moving in a fore/aft plane, and allow spot on positioning every time the cylinder is removed/replaced.
    Also note the tubes at the top end of the cylinder in the hull...they are where the locating pins for the top deck fit. I'm not using those, so I figure that a small strip of brass, drilled and secured into those holes with self tapping screws, will secure the cylinder in position. Clever stuff, huh?
    Skipjack.part 2 - Page 3 Photo_32
    Skipjack.part 2 - Page 3 Photo_33
    Post  Tom(ADMIN) Sun Sep 01, 2013 7:54 am
    Nothing done yesterday, I'm afraid...and here's why.
    Skipjack.part 2 - Page 3 12700310
    Skipjack.part 2 - Page 3 12746410
    Post  Tom(ADMIN) Sun Sep 01, 2013 3:11 pm
    So, what does the team think? I have two brand new Turnigy 9gramme mini servos which I'd like to use in the Skipjack for the rudder (via a MicroGyros leveller) and the rear 'planes...will they be man enough, do we think? Or will I need to use standard size servos?
    Your recommendations please, guys...
    Post  merriman Sun Sep 01, 2013 5:36 pm
    Richard(Admin) wrote:So, what does the team think? I have two brand new Turnigy 9gramme mini servos which I'd like to use in the Skipjack for the rudder (via a MicroGyros leveller) and the rear 'planes...will they be man enough, do we think? Or will I need to use standard size servos?
    'mini' or larger servo recommended.
    Post  Tom(ADMIN) Sun Sep 01, 2013 5:58 pm
    Ok, thanks for that David...larger it will be.
    Post  Tom(ADMIN) Wed Sep 04, 2013 6:47 pm
    I haven't had chance to do much over the last two days due to badly swollen and very painful knees, but this afternoon I managed to make a start on the trays for the cylinder. The gap inbetween the two trays is where the ballast tank will sit. Hopefully I want to cut the ballast tank to size tomorrow, fingers and knees permitting.
    Skipjack.part 2 - Page 3 Photo_34
    Post  acrowot (Geof) Thu Sep 05, 2013 1:20 am
    Hi richard I turn my back For five miniutes and your of building another sub good on you I thought I would see whats happening while I'm waiting for a chinese take away and yes its 1.20 am but I'm sitting in florida watching a nice thunder storm the problem is ill be home friday errr and I promise pictures of u boat keep up the good work richard
    Take care geof
    Post  Tom(ADMIN) Thu Sep 05, 2013 10:05 am
    Hello Geoff...Florida? Obviously got far too much money mate, I can't even afford to go to Eastbourne! Yep, cracking on mate, slowly but surely with this one...what used to take me five minutes to do now takes me an hour, but it's coming.
    And here's the ballast tank cut to size and in it's approximate position inside the cylinder...now to cut the end caps and a couple of baffles.
    Skipjack.part 2 - Page 3 Photo21
    Another small step for model submariners...a giant leap for me!
    Post  Tom(ADMIN) Fri Sep 06, 2013 5:29 pm
    Made a start today on fitting out the cylinder...so far installed are the rudder and dive plane servos, auto leveller, and  the receiver on the rear tray, and the ballast pump on the forward tray (although I may have to move that a little)
    Skipjack.part 2 - Page 3 Photo_35
    Skipjack.part 2 - Page 3 Photo_36
    Skipjack.part 2 - Page 3 Photo22
    Post  Tom(ADMIN) Sun Sep 08, 2013 12:13 pm
    This is the battery layout...a 12v 2200a/h Sub C cell pack in it's own wtc, tucked away in the forward flood area. Once again, Nigel is making the end caps for me for both the battery wtc ad the ballast tank...thanks Nigel.
    Skipjack.part 2 - Page 3 Photo_37
    Skipjack.part 2 - Page 3 Photo_38
    Post  Tom(ADMIN) Mon Sep 09, 2013 4:14 pm
    Made a start on fitting out the rear tray today...wires and cables and bad language in all directions!
    Skipjack.part 2 - Page 3 Photo_39
    Skipjack.part 2 - Page 3 Photo_40
    The ballast bag I ordered from RC-Sub Workshop in Hong Kong (via eBay) arrived earlier, so I thought I'd check it out...think I may have ordered the wrong size, don't you?
    Skipjack.part 2 - Page 3 Photo_41
    Post  Tom(ADMIN) Tue Sep 10, 2013 5:44 pm
    Is it worthwhile installing an inline filter in the inlet pipe to my water pump, chaps?
    Post  tattooed Tue Sep 10, 2013 7:03 pm
    can't do any harm rich but it's only a small bore pipe and i'd think anything able to go through the pipe would go through the pump with no problem
    Post  Tom(ADMIN) Tue Sep 10, 2013 7:48 pm
    You've never seen what's in my bath, mate!
    sloop
    Skipjack.part 2 - Page 3 Empty your bath
    Post  sloop Tue Sep 10, 2013 10:22 pm
    [quote="Richard(Admin)"]You've never seen what's in my bath, mate! [/quote Can we have photos of the bath to make an evaluation.
    John B
    Post  Tom(ADMIN) Wed Sep 11, 2013 7:45 am
    Too late, JB...my carer cleaned the bathroom yesterday before I could oblige you with some pics...
    Post  Tom(ADMIN) Wed Sep 11, 2013 9:05 am
    Yesterday I installed the water ballast pump, it fits perfectly onto the rear end cap. At the moment it's secured with double sided tape, but later on I may drill the end cap and attach it with a couple of M4 brass bolts and nuts.
    Skipjack.part 2 - Page 3 Photo23
    Skipjack.part 2 - Page 3 Photo_42
    Today's job, once the medication kicks in, is to plumb the pump and get the power leads on.
      Current date/time is Thu Nov 21, 2024 8:57 am
