Motor Shaft Help,  14212712
In total there are 6 users online :: 0 Registered, 0 Hidden and 6 Guests :: 1 Bot
Motor Shaft Help,  EmptyTue Oct 29, 2024 4:46 pm by tsenecal
Motor Shaft Help,  EmptySun Oct 20, 2024 2:04 pm by geofrancis
Motor Shaft Help,  EmptyThu Oct 17, 2024 2:34 pm by geofrancis
Motor Shaft Help,  EmptyMon Oct 14, 2024 4:31 pm by geofrancis
Motor Shaft Help,  EmptySat Oct 12, 2024 3:52 pm by geofrancis
Motor Shaft Help,  EmptyFri Oct 11, 2024 8:58 pm by Marylandradiosailor
Motor Shaft Help,  EmptyFri Oct 11, 2024 8:14 pm by geofrancis
Motor Shaft Help,  EmptyThu Oct 10, 2024 3:21 am by tsenecal
Motor Shaft Help,  EmptyWed Oct 02, 2024 11:32 am by geofrancis
    Motor Shaft Help,
    timgarrod
    AMS Website Webmaster
    Motor Shaft Help,  Empty Motor Shaft Help,
    Post  timgarrod Fri Oct 25, 2013 3:03 pm
    Afternoon All,
    I rebuilding the two WTC as fed up with the old darnel box leaking. two question,
    1, what the best tube to use for the cables to go thought to join up the two boxes, was going to PVC waste pipe but didn't bond well.
    2, on the last box the prop shaft went though the wall of the box which didn't help the leaking, so I wanting to put the motor directly on the box wall. the motor are MFAcombo gearboxes but the shaft are bit short. whats the best way to extend them and make them water tight.
    Thanks
    Motor Shaft Help,  Empty Re: Motor Shaft Help,
    Post  david f Fri Oct 25, 2013 3:46 pm
    Hi Tim,
    You may have a look over at the build log I'm doing on the Darnell type XXI. It may spark some ideas off.
    I now have both boxes out but I'm unlikely to reinstate that tube joining the boxes. Too much leak potential! High current wires between the boxes will go via brass nuts and bolts. (See elsewhere on the forum for details) Control circuits - I haven't yet worked out the details but probably a small sealed gland.
    The greased prop shafts have gone but I am not using MFA motors on this one. One problem you have with them  is, as you have found , you need to join shafts. That can take up valuable WTC length. Our Chairman Nigel has some neat ideas on letting MFA shafts into end caps incorporating seals. Maybe he will come in on this.
    I suggest that whatever you do, you put in decent oil type seals (e.g Simrit) and have any univeral joints outside the WTC (again to save your valuable WTC length.) Don't forget that you put sealed lead acid batteries in the wet.
    If you look at the build log you will see that I am testing 2 different flat plate sealing methods. Early testing seems to show that they are both working adequately. Which to choose!? A bit more testing time will tell.
    timgarrod
    Post  timgarrod Fri Oct 25, 2013 4:42 pm
    thanks david. I check out that build log
    Cheers
    Tim
    Post  Tom(ADMIN) Fri Oct 25, 2013 4:47 pm
    Don't know if this will help, Tim, but I made this up this afternoon out of redundant MMB Sub Sonic parts....took me about half an hour to make.
    It's basically an MMB end cap with a short length of alloy tube cut to go through it, two of his PTFE bearings and a tiny O ring pushed into the ends, then the whole lot goes through one of his Sub Sonic motor mounts. At the inboard end is a brass wheel collet ( a push fit) to take up any slack. A short stub shaft goes through the whole lot and with a couple of Huco connectors and brass thrush washers at both ends, the job is done.
    The motor mount can be trimmed shorter than mine if you need to, but I have plenty of space in the wtc, so I didn't bother doing that. I did run it for a few minutes on 2.4volts, and it ran perfectly freely.
    Motor Shaft Help,  Photo_25
    Motor Shaft Help,  Photo_26
    Motor Shaft Help,  Photo_27
    Post  Tom(ADMIN) Fri Oct 25, 2013 4:51 pm
    I can do you a drawing of it if you wish?
    I'd done the drawing anyway, so here it is...hope it helps.
    Motor Shaft Help,  Untitl11
    timgarrod
    Post  timgarrod Fri Oct 25, 2013 5:27 pm
    cheers Richard, I had a look at them online not sure why I didn't go this route. Just order two oil seals from Simply bearing and like on you x type.
    Have to admit, I would recommend this company to any one, after 30min of ordering online got a email saying order complete and dispatched to royal mail, plus free delivery.
    Post  Tom(ADMIN) Fri Oct 25, 2013 5:29 pm
    That's pretty good service, Tim...can't complain at that!
    Good luck mate, keep us posted.
    timgarrod
    Post  timgarrod Fri Oct 25, 2013 5:36 pm
    taken some photos, so will post when done. at least very time i rebuild it I'm learning and improving.
    Post  profesorul Fri Oct 25, 2013 5:41 pm
    Motor Shaft Help,  Photo_11
    What are those 2 Flange for RICHARD?
    Post  Tom(ADMIN) Fri Oct 25, 2013 6:22 pm
    They are part of the motor mount, Marius...I don't know why they are there really, one would be more than sufficient.
    Post  david f Sat Oct 26, 2013 11:37 am
    That looks very neat, Richard. (And not a million miles from the method Nigel uses.)
    My method for seals has not changed in years and involves a "sandwiched" oil seal on the end of a brass M8 bolt which has been drilled out to 4mm.  But it does require a lathe which not everyone has. Works very reliably for me. Some of those Simrit oil seals have been in my subs for many years.
    And yes Simply Bearings offer a great service and they are based in the North!
    While I am sharing things, I have found some "magic dimensions" for model submarines:
    4mm OD  - for prop shafts, push rods through bellows, air and water connections (using 4mm OD nylon tube)
    42 inches - that model length which allows you to place it full length on the back seat of a car!
    Post  Tom(ADMIN) Sat Oct 26, 2013 1:37 pm
    Here you are Tim....the completed mount fixed on the end cap and in position.
    Motor Shaft Help,  Photo_28
    Motor Shaft Help,  Photo_29
      Current date/time is Thu Nov 21, 2024 1:15 pm
