water tight seal for motor shaft 14212712
In total there are 18 users online :: 0 Registered, 0 Hidden and 18 Guests :: 1 Bot
water tight seal for motor shaft EmptyTue Oct 29, 2024 4:46 pm by tsenecal
water tight seal for motor shaft EmptySun Oct 20, 2024 2:04 pm by geofrancis
water tight seal for motor shaft EmptyThu Oct 17, 2024 2:34 pm by geofrancis
water tight seal for motor shaft EmptyMon Oct 14, 2024 4:31 pm by geofrancis
water tight seal for motor shaft EmptySat Oct 12, 2024 3:52 pm by geofrancis
water tight seal for motor shaft EmptyFri Oct 11, 2024 8:58 pm by Marylandradiosailor
water tight seal for motor shaft EmptyFri Oct 11, 2024 8:14 pm by geofrancis
water tight seal for motor shaft EmptyThu Oct 10, 2024 3:21 am by tsenecal
water tight seal for motor shaft EmptyWed Oct 02, 2024 11:32 am by geofrancis
    willte
    water tight seal for motor shaft Empty water tight seal for motor shaft
    Post  willte Sun Feb 16, 2014 7:19 pm
    I have been thinking of a water tight seal for a jp 400 motor which has brass bushes using silicon tube as a coupling and fitting a eyelet or similar to the front of the motor with the silicon giving it a bit of tension. similar to a type of water pump seal, any comments on this will be welcome
    water tight seal for motor shaft Empty Re: water tight seal for motor shaft
    Post  Tom(ADMIN) Sun Feb 16, 2014 8:09 pm
    Willie, Nigel is the man for this...I'll send him along.
      Current date/time is Thu Nov 21, 2024 10:06 am
