I have been trying this out where the control rod exits the brass tube I fitted heat shrink tube to it the rod slips through with no problem a little c a on the brass tube to secure and try to blow through it no chance. I might be mad but I might try it on the shafts
In total there are 13 users online :: 0 Registered, 0 Hidden and 13 Guests :: 1 Bot
Our users have posted a total of 12481 messages in 1987 subjects
We have 1019 registered users
water tight seals
willte- Guest
water tight seals
Re: water tight seals
Hi, Try silicon tube thats what I always use works very well.
willte- Guest
I have used it on krick U-boat its there way of sealing the plastic control cable
Deep Diver (Fred)- AMS member
Alf Blake used the plastic snake control rods, and he would cut the outer cove, then he placed two small "O" rings out of a gas lighter onto the inner rod, he then left a gap of 5mm, between the "O" rings, covered the outer and the gap area with heat shrink. there by fixing the "O" with the heat shrink. the inner rod can still move and the water is stopped by the "O" rinds.
» David Forrest's R class
» bladder bags
