My ballast pump controller. 14212712
In total there are 34 users online :: 0 Registered, 0 Hidden and 34 Guests :: 1 Bot
My ballast pump controller. EmptyTue Oct 29, 2024 4:46 pm by tsenecal
My ballast pump controller. EmptySun Oct 20, 2024 2:04 pm by geofrancis
My ballast pump controller. EmptyThu Oct 17, 2024 2:34 pm by geofrancis
My ballast pump controller. EmptyMon Oct 14, 2024 4:31 pm by geofrancis
My ballast pump controller. EmptySat Oct 12, 2024 3:52 pm by geofrancis
My ballast pump controller. EmptyFri Oct 11, 2024 8:58 pm by Marylandradiosailor
My ballast pump controller. EmptyFri Oct 11, 2024 8:14 pm by geofrancis
My ballast pump controller. EmptyThu Oct 10, 2024 3:21 am by tsenecal
My ballast pump controller. EmptyWed Oct 02, 2024 11:32 am by geofrancis
+2
6 posters
    My ballast pump controller. Empty My ballast pump controller.
    Post  Tom(ADMIN) Tue Feb 18, 2014 11:47 am
    Made a start on making the bits that I'll be needing for HMS P222...this is ballast pump controller.
    Land Rover screenwash pump and an Mtroniks Micro Viper 15amp esc, mounted on a styrene plate.
    My ballast pump controller. Mysurf20
    My ballast pump controller. Empty Re: My ballast pump controller.
    Post  tattooed Tue Feb 18, 2014 6:09 pm
    and the mans off again looking good mate keep it going
    Post  Tom(ADMIN) Tue Feb 18, 2014 6:29 pm
    The man's feeling better, mate...the S is due tomorrow, so I'm getting ready.
    willte
    Post  willte Thu Feb 20, 2014 9:46 pm
    here a question for you that pumps are the sealed type do you think they can be used out side of the wtc
    Post  Tom(ADMIN) Thu Feb 20, 2014 10:29 pm
    I've never tried to use a pump externally, Willie...I don't know what would happen to it, or how long it would last. I would guess it's probably not a good idea, but I don't know for sure.
    willte
    Post  willte Fri Feb 21, 2014 1:51 pm
    the reason for asking the pumps are too big for my tube an less you take the tubes out of the side of the tube, bought a two tube ballast bag from hongkong
    Post  Deep Diver (Fred) Fri Feb 21, 2014 2:19 pm
    there was one that would work outside of the w/c, will have a look for the info when I get home, just have to remember.
    Post  profesorul Mon Mar 17, 2014 11:03 am
    HI there ,
    Question :
    das these Speed Controller work with Sealed Pb-Ac Battery or Ni Cd/NiMh Battery ?
    My ballast pump controller. Viperm10
    These Speed controller I want them for my LOS Angeles MOTOR (see picture) and That Specific Battery (from the same picture) :
    My ballast pump controller. Img_0225
    and these Speed Controller for these Pump :
    My ballast pump controller. Water_10
    Well They fit as characteristics/Specs ?
    Post  david f Mon Mar 17, 2014 11:51 am
    That speed controller is the one I often use and it will work with all battery types (lead acid etc.) (I even use them with Lipos but, of course, this model will not give low voltage warnings.)
    Post  Deep Diver (Fred) Mon Mar 17, 2014 3:28 pm
    The pump that I was on about in my post dated the 21st is made by Bohler, it has a capacity of 8lpm,H100mm Dia 30mm cost at the time was £15.00
    Post  profesorul Tue Mar 18, 2014 9:28 am
    HI FRED ,
    Is these Your Pump:
    My ballast pump controller. Bohler11 ?
    Is not too big for a sub ? . What are the dimensions ? .Is working ONLY with 12VDC , if so Is not good for me !.
    Post  Deep Diver (Fred) Tue Mar 18, 2014 3:15 pm
    Yep that is the one, yes it is 12v, but the boat that I had it in was on 12v, you may be lucky and it may work on 6v, if I could I would say have a look at Hunter Systems but as I can not say this please do not have a look.
    h = 100mm
    Outlet external = 9.5mm with a step up to =10.75mm
    pump body diameter = 30mm
    All the best
    Fred
    All of the above is not the opinion of the AMS.
    Post  profesorul Tue Mar 18, 2014 3:58 pm
    THANK YOU ,
      Current date/time is Thu Nov 21, 2024 9:03 am
