newbee confused 14212712
In total there are 40 users online :: 0 Registered, 0 Hidden and 40 Guests
newbee confused EmptyTue Oct 29, 2024 4:46 pm by tsenecal
newbee confused EmptySun Oct 20, 2024 2:04 pm by geofrancis
newbee confused EmptyThu Oct 17, 2024 2:34 pm by geofrancis
newbee confused EmptyMon Oct 14, 2024 4:31 pm by geofrancis
newbee confused EmptySat Oct 12, 2024 3:52 pm by geofrancis
newbee confused EmptyFri Oct 11, 2024 8:58 pm by Marylandradiosailor
newbee confused EmptyFri Oct 11, 2024 8:14 pm by geofrancis
newbee confused EmptyThu Oct 10, 2024 3:21 am by tsenecal
newbee confused EmptyWed Oct 02, 2024 11:32 am by geofrancis
      newbee confused
      mickonos
      newbee confused Empty newbee confused
      Post  mickonos Thu Feb 27, 2014 7:59 pm
      greetings earthlings, im a newcomer to subs and jumped in at the deep end and brought an engel typhoon, im no stranger to radio controlled models having been flying aircraft for about 15yrs, ive brought a 40mhz module for my ff9 and having 9 channels to play with i thought ide be ok, but the engel manual and plans show a robbe decoder, can someone tell me what this does and do i need it please
      newbee confused Empty Re: newbee confused
      Post  Tom(ADMIN) Thu Feb 27, 2014 8:10 pm
      I'm no expert on techie stuff, but I think you'll need all the bells and whistles installed in your tx to run the Typhoon. There's an awful lot of stuff in that boat that needs separate channels, so I'd think you'd need the full house.
      Have a look at Westbourne Models website, they do most of the Robbe modules and decoders, etc.
      Post  nigele(ADMIN)2 Thu Feb 27, 2014 8:46 pm
      Hi,
      A robbe decoder splits one channel into several, to do this you require a multiprop decoder in the boat this plugs into one channel on the receiver, you also require a multi switch unit in the tx, not cheap but it will increase the amount of channels by at least six.
      look on ebay particularly Germany,I also think westbourne models keep them in stock.
      mickonos
      Post  mickonos Thu Feb 27, 2014 9:37 pm
      the manual says 3 channels for the tmax dive sysyem, one for rudder, throttle, dive planes, dive planes retract, bow truster and periscope which is 9 channels, so if im using an ff9 will i be ok, also is the robbe switch unit and decoder compatable with a futaba ff9
      Post  nigele(ADMIN)2 Thu Feb 27, 2014 9:54 pm
      Hi,
      you should be ok with 9 channels I think,I dont think that you would be able to use the ff9 with a robbe decoder,not because they are incompatible but simply from what I can remember the ff9 has no provision for the switch unit in the case,check with westborne models they will be able to tell you.
        Current date/time is Thu Nov 21, 2024 9:15 am
