Graupner X-408 Transmitter 14212712
In total there are 51 users online :: 0 Registered, 0 Hidden and 51 Guests :: 3 Bots
Graupner X-408 Transmitter EmptyTue Oct 29, 2024 4:46 pm by tsenecal
Graupner X-408 Transmitter EmptySun Oct 20, 2024 2:04 pm by geofrancis
Graupner X-408 Transmitter EmptyThu Oct 17, 2024 2:34 pm by geofrancis
Graupner X-408 Transmitter EmptyMon Oct 14, 2024 4:31 pm by geofrancis
Graupner X-408 Transmitter EmptySat Oct 12, 2024 3:52 pm by geofrancis
Graupner X-408 Transmitter EmptyFri Oct 11, 2024 8:58 pm by Marylandradiosailor
Graupner X-408 Transmitter EmptyFri Oct 11, 2024 8:14 pm by geofrancis
Graupner X-408 Transmitter EmptyThu Oct 10, 2024 3:21 am by tsenecal
Graupner X-408 Transmitter EmptyWed Oct 02, 2024 11:32 am by geofrancis
    Kevin D
    Graupner X-408 Transmitter Empty Graupner X-408 Transmitter
    Post  Kevin D Wed Aug 20, 2014 10:53 pm
    I have purchased two NOS Graupner X-408 40mhz 4 channel transmitters without receivers. Does anyone know what make receivers are compatible with these, other than Graupner. I have tried my Futaba receiver but that does not work.
    Hoping these aren't lame ducks !!!
    Graupner X-408 Transmitter Empty Re: Graupner X-408 Transmitter
    Post  david f Tue Aug 26, 2014 12:00 pm
    I have had a look at the (English) instruction manual for these and all the basics look fine, because it is:
    - FM
    -PPM
    -1.5 m seconds range for the servos.
    If your Futaba receiver had the right crystals you should have got some response.
    Anyone any ideas?
    Kevin D
    Post  Kevin D Tue Aug 26, 2014 12:34 pm
    Thanks David, I hadn't really thought about crystal compatibility, I had 40mhz Futaba compatible crystals in both TX and RX.
    I haven't generally experienced any issues with mix and match on my 27mhz gear which I use for fast electric boats, so I didn't really think about it.
    Could that be my problem?
    Post  david f Wed Aug 27, 2014 12:12 pm
    Crystals are a bit of a black art but I thought Futaba would be some sort of standard.
    You've presumably got the right type in the receivers (Dual or Single conversion.)
    Anyone any experience of Graupner and crystals?
      Current date/time is Thu Nov 21, 2024 10:24 am
