Camcorder Mount to Transmitter 14212712
In total there are 39 users online :: 0 Registered, 0 Hidden and 39 Guests :: 2 Bots
Camcorder Mount to Transmitter EmptyTue Oct 29, 2024 4:46 pm by tsenecal
Camcorder Mount to Transmitter EmptySun Oct 20, 2024 2:04 pm by geofrancis
Camcorder Mount to Transmitter EmptyThu Oct 17, 2024 2:34 pm by geofrancis
Camcorder Mount to Transmitter EmptyMon Oct 14, 2024 4:31 pm by geofrancis
Camcorder Mount to Transmitter EmptySat Oct 12, 2024 3:52 pm by geofrancis
Camcorder Mount to Transmitter EmptyFri Oct 11, 2024 8:58 pm by Marylandradiosailor
Camcorder Mount to Transmitter EmptyFri Oct 11, 2024 8:14 pm by geofrancis
Camcorder Mount to Transmitter EmptyThu Oct 10, 2024 3:21 am by tsenecal
Camcorder Mount to Transmitter EmptyWed Oct 02, 2024 11:32 am by geofrancis
    Camcorder Mount to Transmitter Empty Camcorder Mount to Transmitter
    Post  merriman Sun Jul 19, 2015 4:46 pm
    The internet; small, relatively cheap camcorders; the ease and facility to edit and store recorded scenes. All have given us the ability to video record our activities at the boating site. Yet few of us do because of the hassle involved in getting someone to handle the camcorder, and be trusted to get the scenes recorded the way we want; and its awkward to keep turning our attention away from the water to give direction to the camera operator. So those great shots of our model submarine surfacing, submerging and stoutly making the local watering hole safe for democracy/communism/ the national socialists party/the Emperor/the peoples republic, etc. Just does not get done. An individual simply can't handle the transmitter AND a camcorder at the same time and do either task well.
    But, wait! What's that in our hands.? Yes!, it's a transmitter!
    Well, moron,  why not make that transmitter useful and affix to it a specialized camera mount?
    Simply attach the camcorder to the transmitter with a dedicated camera mount and you've eliminated the camera-man. This way you point the camera where you want it, and its large flat-screen view-finder permits you to orient the transmitter so the video being recorded is framed correctly.
    The trick is devising the camcorder-transmitter interface mount. And that's what I'm presenting here: a special camera mount with bracket that attaches to the transmitters carrying handle; an interface mechanism between transmitter and camcorder.
    ( If your transmitter does not have a handle, then a little re-design will produce a camera mount that screws directly to the transmitter case. Just make sure there are no circuit boards or other vital organs within the area being worked that would be damaged as your drill and tap holes atop the transmitter case).
    Camcorder Mount to Transmitter Dscf5411
    As you can see here -- if your transmitter has a carrying handle -- it's a rather straightforward process to devise a camera mount that will hang off of it. So oriented, the camera view-screen is in the direct line-of-sight of the operator, and also sits clear of the transmitters antenna.
    My version of the camera mount permits both pan,  tilt and transverse adjustments. This ability situates the camera so it's aimed at the image you want captures, yet permits a comfortable orientation of the transmitter, suited to your normal operational posture.
    Camcorder Mount to Transmitter Dscf5412
    The camera mount can be slide horizontally on the handle so that your view of the view-finder screen and access to the cameras controls is unobstructed by the transmitters antenna. Today's cameras, with their big and bright view-finder displays make easy the task of holding the subject in frame -- even with the camera a good foot-and-a-half away from your eyes -- as you control the submarine model from the transmitter.
    A word of caution: splitting your attention between transmitter and camera is fine for relatively slow submarines, but not at all recommend for model aircraft or fast boats and cars. You wouldn't text-and-drive.
    Don't video-and-fly!
    Camcorder Mount to Transmitter Dscf5316
    This makes clear how the camcorder mount is secured to the horizontal leg of the transmitter handle. The serrated thumb-screw started life as a length of brass pinion gear 'wire' I had left over from a job. The gear teeth making the perfect high-friction perimeter of the thumb-screw used to hold the camcorder down tight on the mount.  The stock was chucked up in the lathe, the end of the pinion stocked faced, and bored, and tapped with a 1/4-20 thread.  I then parted off two 1/4" wide pieces and later glued short lengths of 1/4-20 stainless-steel all-thread to each thumb-screw wheel (I made two camera-to-transmitter mounts).
    The tilt angle of the camcorder to the transmitter is changed by loosening one of the bracket screws, pitching the mount to the desired angle, and retightening the bracket screw. Pan angle is set with the mounts thumb-screw: Loosen it, yaw the camera in the direction desired, then re-tighten the thumb-screw.
    Camcorder Mount to Transmitter Dscf5321
    In this  Illustrated you see the rejected concept sketches below and to the left of the accepted design. All on paper, before the first piece of brass stock was pulled off the rack. Make things evolve in your head, not the work-bench ... or you wind up with a Rube Goldberg monstrosity!
    When coming up with a gizmo like this camera mount, things start off as a brain-storm over breakfast; takes mental form during my hideous morning walk; and the ... wait for it ... eureka! moment hits me in the bathroom; I then rush to the shop (invariably, a piece of toilet paper trailing behind me), break out the graph-paper and start doodling orthographic projections before the idea has a chance to evaporate.
    One version ... nope, too complex. Next version ... nope, to damned weak. Each new study -- now in two-dimensional form -- staring accusingly back at me from the graph-paper. Each study an attempt to simplify and enhance the function of the proposed device.  On and on, till the thing starts making good sense.
    Then one final doodle: This one in isometric to capture in one drawing both height, width, and depth -- a good way to identify interference problems and any paradox between plan and profile views. A good check before starting the actual work.
    To the metal stock rack. Is the stuff I need on hand to do the job? If need be the drawing is modified to suite what I have on hand.  The materials identified on hand I set to work. Machine brass for the parts to be milled and turned; cartridge brass for those items that will be sawed and bent. Both alloys easy to solder, and look snazzy when polished out. Perfect.
    "TO THE BAT-CAVE!"
    Camcorder Mount to Transmitter Dscf5319
    An assembled and ready to use camcorder mount to the left. The parts for another camcorder mount to the right.
    Note how a bracket plate is screwed down over the transmitter handle to make fast the mount to the transmitter. The camcorder mount can be removed or installed in less than a minute. Tilt angle is adjusted by loosening the bracket screws, positioning the camera mount, and re-tightening the bracket screws -- an adjustment to  suit the unique transmitter handling style of the operator.
    Camcorder Mount to Transmitter Dscf5320
    The majority of the camera mount components were assembled with soft solder.
    Camcorder Mount to Transmitter Dscf5327
    Ellie's demonstrating how the camcorders big view-finder is easily seen as the transmitter is used to both control the r/c model submarine and serve as a base for the camcorder.
    As your eyes are focused on the submarine on or under the water, a quick glance every now and then at the camcorder screen tells you where to point the transmitter to keep the action centered where you want it. Also, the mass of the transmitter is an aid in that it helps damp out operator induced shaking that would otherwise spoil the shot.
    Here's a YouTube video taken with a transmitter mounted camcorder:
    https://youtu.be/meh-QwA2fYE
    Camcorder Mount to Transmitter Empty Re: Camcorder Mount to Transmitter
    Post  Tom(ADMIN) Sun Jul 19, 2015 9:01 pm
    Nice solution! As always, you are willing to show the steps so others can learn.
    Thank you.
    Post  merriman Sun Jul 19, 2015 10:20 pm
    Tom(ADMIN) wrote:Nice solution! As always, you are willing to show the steps so others can learn.
    Thank you.
    I stand tall on the shoulders of those who came before me; those who shared their wisdom and creativity. Just passing it on. Thanks, Tom.
    Post  david f Mon Jul 20, 2015 9:39 am
    That's a really nice solution to all those wobbly camera shots. (Of which, I have made a few - too few to mention!)
    My slow machining skills sadly means that I would not be able to make this before next weekend's Norwich sub event. So stand by for a few more wobbly shots!
    Post  merriman Mon Jul 20, 2015 10:51 am
    david f wrote:That's a really nice solution to all those wobbly camera shots. (Of which, I have made a few - too few to mention!)
    Standing by, sir!
    An alternative is to decapitate a tripod and duct-tape the gore to your transmitter ...
    Post  tsenecal Mon Jul 20, 2015 7:49 pm
    since so many of us now use our smart phones....   instead of those pesky "cameras" as my grandparents used to call them :)
    i came across a wonderful identical in concept item that was originally intended for the idiots that fly drones.   i found it on ebay, and it is a spring loaded clamp that attaches my phone to my transmitter.
    search for "fpv transmitter cell phone clip"
    Camcorder Mount to Transmitter Clip10
    Post  tsenecal Mon Jul 20, 2015 7:52 pm
    David,  who was the target driver in that youtube video?  did he not see the sub?
    and for an individual that is smart enough to find this... yet is stupid enough not to see the initial comment for the youtube video: "1/144 scale BURK chases 1/96 SKIPJACK"... however, i still must say... 3 feet behind is chasing... 3 inches behind is collision..."
    Post  merriman Mon Jul 20, 2015 8:56 pm
    tsenecal wrote:since so many of us now use our smart phones....   instead of those pesky "cameras" as my grandparents used to call them :)
    Now THAT is slick! A very good piece of engineering there. And aimed at the 'phone' users. Good catch, sir!
    Post  merriman Mon Jul 20, 2015 9:23 pm
    tsenecal wrote:David,  who was the target driver in that youtube video?  did he not see the sub?
    That's my long time r/c buddy, Kevin Rimrodt. He's one of the first guys to attempt a wireless video system within an r/c submarine. And not only a good/crazy driver, but also an excellent Craftsman.
    Oh, let me assure you, he saw me! That video was shot last weekend at the Nauticus Maritime centers fresh water Koi ponds where our regional r/c model boat club, the Elite Fleet, puts on a public show every month of the summer.
    As part of our exhibit Kevin and I put on a cat-and-mouse ASW ship vs. submarine battle. He puts in his 1/144 BURK class destroyer, I put in either my 1/96 SKIPJACK or 1/144 KILO, and we tear up the water. The object of the game is to maneuver in such a way as to put yourself on the stern of your opponent. As we don't employ model torpedoes or depth charges (yes, I know, 'old' technology) we concentrate on tight, high-speed turns to achieve positional advantage.
    Kevin and I tend to get 'into it' and paint has been swapped on more than one occasion. What I diplomatically describe as, 'weathering on the fly'.
    Here's a slower engagement from earlier this year:
    https://www.youtube.com/watch?v=bo9Mp9nuoB4
    Oh, and let me express my appreciation of the heavy lifting -- working out how we can get onto a more submarine-friendly r/c band -- you've been doing since the industry dropped all 75mHz r/c system production. I think it likely that your work will be regarded as the one thing that saved our hobby from extinction.
      Current date/time is Thu Nov 21, 2024 11:26 am
