Akula 1/144 scratch build - Page 3 14212712
In total there are 42 users online :: 0 Registered, 0 Hidden and 42 Guests :: 1 Bot
Akula 1/144 scratch build - Page 3 EmptyTue Oct 29, 2024 4:46 pm by tsenecal
Akula 1/144 scratch build - Page 3 EmptySun Oct 20, 2024 2:04 pm by geofrancis
Akula 1/144 scratch build - Page 3 EmptyThu Oct 17, 2024 2:34 pm by geofrancis
Akula 1/144 scratch build - Page 3 EmptyMon Oct 14, 2024 4:31 pm by geofrancis
Akula 1/144 scratch build - Page 3 EmptySat Oct 12, 2024 3:52 pm by geofrancis
Akula 1/144 scratch build - Page 3 EmptyFri Oct 11, 2024 8:58 pm by Marylandradiosailor
Akula 1/144 scratch build - Page 3 EmptyFri Oct 11, 2024 8:14 pm by geofrancis
Akula 1/144 scratch build - Page 3 EmptyThu Oct 10, 2024 3:21 am by tsenecal
Akula 1/144 scratch build - Page 3 EmptyWed Oct 02, 2024 11:32 am by geofrancis
+6
Dr.Schmidt
bwi
10 posters
    Akula 1/144 scratch build - Page 3 Empty Re: Akula 1/144 scratch build
    Post  Tom(ADMIN) Wed Jun 29, 2016 10:14 pm
    Fantastic work. It shows great attention to details.
    bwi
    bwi
    Post  bwi Thu Jun 30, 2016 6:01 pm
    Thks Tom!
    Grtz,
    Bart
    bwi
    bwi
    Akula 1/144 scratch build - Page 3 Empty Touchup scibing lines
    Post  bwi Thu Jun 30, 2016 6:24 pm
    I did the touchup of the scribing lines (thks to Andrew Lawrence I found the right putty that does not affect the paint) ......time consuming but afterwards I was amazed with the amount of damage that became visible when it was filled with red putty (most of the damage were broken off paint chips around the edges).It’s was worth the effort.
    Grtz,
    Bart
    Akula 1/144 scratch build - Page 3 Akula_511
    Akula 1/144 scratch build - Page 3 Akula_509
    Akula 1/144 scratch build - Page 3 Akula_508
    Akula 1/144 scratch build - Page 3 Akula_507
    Akula 1/144 scratch build - Page 3 Akula_506
    bwi
    bwi
    Akula 1/144 scratch build - Page 3 Empty WTC saddles
    Post  bwi Thu Jun 30, 2016 6:31 pm
    Made the saddles for the SD. The saddles are made of 9mm styrene sheet (3 pieces of 3mm glued/melted together).
    I will provide some hooks in the saddles to keep the SD pushed in the saddles with rubber bands, yep that's why they are 9mm wide, need some flesh to screw the hooks in.
    They are both provided with a recess, to prevent the longitudinal movement of the SD, and when the SD is placed in the sub it will always sit in the same position.
    As my SD is hanging, the saddles are partly above the water in surfaced condition. So I needed to keep the weight of the saddles as low as possible. The lift capacity of the SD is limited, I previous calculated I have some spare but I need to keep things light above the waterline. That’s why I drilled some holes in it, 25 gr (0.88 oz) together, not bad at all.
    To let prevent air pockets when diving I provided some channels on the edges of the saddles. One suggestion drill the holes before you cut out the desired shape of the saddles else you will not be able to drill those holes i.w.o. the edges.
    And YES I thought about it before I made the cut
    Grtz,
    Bart
    Akula 1/144 scratch build - Page 3 Akula_525
    Akula 1/144 scratch build - Page 3 Akula_524
    Akula 1/144 scratch build - Page 3 Akula_523
    Akula 1/144 scratch build - Page 3 Akula_522
    Akula 1/144 scratch build - Page 3 Akula_517
    Akula 1/144 scratch build - Page 3 Akula_527
    Akula 1/144 scratch build - Page 3 Akula_519
    bwi
    bwi
    Akula 1/144 scratch build - Page 3 Empty Bow planes
    Post  bwi Thu Jun 30, 2016 6:44 pm
    Design and fabrication progress of the bow planes linkages. Two days’ work…….......need one more day to finish it
    Grtz,
    Bart
    Bushings:
    Bushings dia 3mm, bore dia 2mm length 5mm
    Akula 1/144 scratch build - Page 3 Akula_588
    Akula 1/144 scratch build - Page 3 Akula_589
    Supports:
    Everything starts with making the required materials, 4 pc of 3mm styrene glued together to the required thickness of 12mm. Sanded everything square/perpendicular so I had a good base to start with. Strange shape? No I have to give room to the Fwd index lip of the lower hull, see below for the assembly.
    Cut out the desired shape, provided with 3mm bores to take the bushings.
    Akula 1/144 scratch build - Page 3 Akula_594
    Akula 1/144 scratch build - Page 3 Akula_590
    Akula 1/144 scratch build - Page 3 Akula_585
    Akula 1/144 scratch build - Page 3 Akula_582
    Bell-cranks:
    made out styrene sheet, provided with a 2mm bore in the center piece and the arms are provided with a 1.5mm bore. Pitch is 10mm except the one with the longer arm pitch of that one is 15mm, will see which one I will use (probably the one with the 10mm pitch. That will give me app 30° deflection as per David Merriman's instructions.
    Akula 1/144 scratch build - Page 3 Akula_581
    Akula 1/144 scratch build - Page 3 Akula_580
    Assembly
    Test fitting the assembly (parts are not yet completed).
    Akula 1/144 scratch build - Page 3 Akula_578
    Akula 1/144 scratch build - Page 3 Akula_595
    bwi
    bwi
    Akula 1/144 scratch build - Page 3 Empty Yokes
    Post  bwi Thu Jun 30, 2016 7:00 pm
    Working on the yokes.
    Challenges
    • Pushrod movement rear planes 7mm
    • Pushrod movement rudders 10mm
    • Need about 35° deflection on the rudders and planes.
    Yokes fabrication
    Collars made out of brass, outer diameter 8mm (5/16), rod bore 2mm (3/32), screw 2mm (3/32).
    Bridge 2mm (1/16) brass rod
    Work in progress, testfitting the yokes
    Akula 1/144 scratch build - Page 3 Akula_603
    Akula 1/144 scratch build - Page 3 Akula_604
    Akula 1/144 scratch build - Page 3 Akula_608
    Bell crank Arm.
    In order to get the deflection of 35°, a very short arm was necessary. The pitch could not exceed 6mm. It was impossible to use the usual Z-bent pushrods the rod would hit the collar restricting the deflection to 10°.
    I came up with the following construction to make it work.
    A brass bushing with outer diameter 4mm (???) and inner diameter 3mm (1/8) was fabricated and soldered to the brass pushrod of 1.5mm (1/16).
    An arm was fabricated out of 1mm (1/32) brass sheet. Two holes were drilled in the arm, pitch 5mm.
    An pin was made out of 3mm (1/8) brass rod and provided with a hole to take a 2mm (3/32) screw.
    The pin was soldered to the arm, and the arm was soldered to the yoke.
    The bushing of the pushrod pivots over the pin the screw holds the assembly together, preventing the bushing to slide of the pin.
    Ready to solder
    Akula 1/144 scratch build - Page 3 Akula_602
    All parts
    Akula 1/144 scratch build - Page 3 Akula_598
    Akula 1/144 scratch build - Page 3 Akula_597
    Assembled together.
    Akula 1/144 scratch build - Page 3 Akula_600
    Akula 1/144 scratch build - Page 3 Akula_599
    Finished the last one........test fitted everything........works like a charm.
    I have included some more detailed pics while fabricating the second one.
    Akula 1/144 scratch build - Page 3 Akula_613
    Akula 1/144 scratch build - Page 3 Akula_635
    Akula 1/144 scratch build - Page 3 Akula_632
    Akula 1/144 scratch build - Page 3 Akula_631
    Akula 1/144 scratch build - Page 3 Akula_630
    Akula 1/144 scratch build - Page 3 Akula_614
    Akula 1/144 scratch build - Page 3 Akula_616
    Akula 1/144 scratch build - Page 3 Akula_626
    bwi
    bwi
    Akula 1/144 scratch build - Page 3 Empty SOKS
    Post  bwi Thu Jun 30, 2016 7:29 pm
    I'm working on the SOKS I have been doing some testing in the past regarding fabrication, more specific what is the smallest diameter I can manage.
    Brass 1.5mm rod turned down diameter 1mm is the smallest I can do so I can still produce almost exact copy's.
    I have divided them into 4 categories:
    Spikes (5pc)
    Tamps (7pc)
    Drops (7pc)
    Protectors (5pc)
    This evening I finished the spikes, the 1.5mm rod needs to be trimmed down, for the moment I leave it on.
    Akula 1/144 scratch build - Page 3 Akula_643
    Akula 1/144 scratch build - Page 3 Akula_641
    Akula 1/144 scratch build - Page 3 Akula_640
    Akula 1/144 scratch build - Page 3 Akula_644
    Akula 1/144 scratch build - Page 3 Akula_642
    Almost finished eyeballing my lathe true the magnifier lamp......only the five protectors left.
    I have marked the tamps with red to distinguish them from the spikes with the naked eye.
    Akula 1/144 scratch build - Page 3 Akula_668
    Akula 1/144 scratch build - Page 3 Akula_674
    Drilling the SOKS holes in the sail.
    The surface of the sail where I have to drill the hols in is angled and double curved to make things easier.
    So I had to make an template to guide the 1mm drill while drilling and to make sure the drilled holes were parallel to the longitudinal axis of the sub.
    The template was temporary fitted in the right position and the holes were drilled by turning the drill between the fingers, this made me feel what I was doing.
    And NO there are not to many holes 10 for the SOKS and 5 for the protectors.
    Akula 1/144 scratch build - Page 3 Akula_648
    Akula 1/144 scratch build - Page 3 Akula_647
    Akula 1/144 scratch build - Page 3 Akula_644_01
    Akula 1/144 scratch build - Page 3 Akula_650
    Akula 1/144 scratch build - Page 3 Akula_646
    Akula 1/144 scratch build - Page 3 Akula_649
    Grtz,
    Bart
    bwi
    bwi
    Post  bwi Wed Oct 05, 2016 8:03 pm
    Propeller finishing diameter 40mm (1.6").
    ​ 2 blades of the prop were slightly off regarding the diameter....It was starring at me every time I looked at the propeller.......so I needed to address.
    The problem is You can't heat 2 blades without melting the solder of all the others.
    I took a piece of pipe turned the inner diameter to the required diameter of the propeller 40 mm in my case.
    Made a support for the blade roots, mounted the propeller on the jig with the root support, put the pipe over the propeller, filled the casing with sand halve way the propeller height, wetted the sand with water and heated everything up. When everything was hot enough I adjusted the blades till they touched the pipe casing and let everything cool down again. Put the propeller on the lath, turned the lath on, and I saw a perfect propeller NO MORE STARING.
    Akula 1/144 scratch build - Page 3 Akula_(661)
    Akula 1/144 scratch build - Page 3 Akula_(665)
    Akula 1/144 scratch build - Page 3 Akula_(663)
    Akula 1/144 scratch build - Page 3 Akula_(664)
    While I was doing that I thought lets finish this thing........I saw on some pictures that sometimes the propeller of the AKULA's is provided with zinc anodes.....I casted some anodes with use of solder, they are approxiatly 1.5mm in diameter, and glude them on the hub.
    Now the propeller can go into the finished box.
    Akula 1/144 scratch build - Page 3 Akula_667
    Akula 1/144 scratch build - Page 3 Akula_659
    Akula 1/144 scratch build - Page 3 Akula_658
    Akula 1/144 scratch build - Page 3 Akula_656
    This pic showing the prop of a KILO class I used it as an example for the anodes.
    Akula 1/144 scratch build - Page 3 Image001
    redboat219
    redboat219
    Post  redboat219 Thu May 19, 2022 7:51 am
    What ever happened to this build? It's been 5 years.
      Current date/time is Thu Nov 21, 2024 10:20 am
