Typhoon Doesn't Like Water  14212712
In total there are 10 users online :: 0 Registered, 0 Hidden and 10 Guests :: 1 Bot
Typhoon Doesn't Like Water  EmptyTue Oct 29, 2024 4:46 pm by tsenecal
Typhoon Doesn't Like Water  EmptySun Oct 20, 2024 2:04 pm by geofrancis
Typhoon Doesn't Like Water  EmptyThu Oct 17, 2024 2:34 pm by geofrancis
Typhoon Doesn't Like Water  EmptyMon Oct 14, 2024 4:31 pm by geofrancis
Typhoon Doesn't Like Water  EmptySat Oct 12, 2024 3:52 pm by geofrancis
Typhoon Doesn't Like Water  EmptyFri Oct 11, 2024 8:58 pm by Marylandradiosailor
Typhoon Doesn't Like Water  EmptyFri Oct 11, 2024 8:14 pm by geofrancis
Typhoon Doesn't Like Water  EmptyThu Oct 10, 2024 3:21 am by tsenecal
Typhoon Doesn't Like Water  EmptyWed Oct 02, 2024 11:32 am by geofrancis
    timgarrod
    AMS Website Webmaster
    Typhoon Doesn't Like Water  Empty Typhoon Doesn't Like Water
    Post  timgarrod Sun May 01, 2016 12:33 pm
    weird one. tested my tyhoon and works fine on the bank side but when you put it in the water you lose all power, once the wtc top is just under the water. take it out and comes to life does this every time any ideas.
    Typhoon Doesn't Like Water  Empty Re: Typhoon Doesn't Like Water
    Post  david f Mon May 02, 2016 8:31 am
    Hi Tim,
    By "lose power" do you mean that you still have battery power but the motor turns off?
    If so, it is most probably a radio problem (aerial?) . Try a range test in air?
    Post  nigele(ADMIN)2 Mon May 02, 2016 11:16 am
    If you have an external arial make sure you have sealed the end.
    Post  John Wrennall Mon May 02, 2016 1:43 pm
    Hi Tim
    Does the boat use a BEC or a RX Battery?
    Are the servos still working or is it a TOTAL Power loss?
    Any crystal changes been made?
    Have you been using Russian swear words at it?
    timgarrod
    Post  timgarrod Mon May 02, 2016 5:58 pm
    Hi all, thanks.
    it was total power loss. found the issue now thank to John R(thanks again, I own you one big time).
    The person that built the tyhoon had a light bulb in metal holder bolted to the alu lid to lower the voltage for the rotating radar.
    Also there was ground cable on the front gearbox motor,
    As it's got a water switch to turn the boat on, as soon as the the WTC or the gearbox shaft was just touching the water, it was grounding and the switch was turning the sub off.
    Cheers
    Tim
      Current date/time is Thu Nov 21, 2024 10:10 am
