Questions and answers here.
Topics | Replies | Author | Views | Last Posts | ||
documentation for a robbe seawolf v2 | 3 | geofrancis | 676 | Wed May 10, 2023 5:08 pm by geofrancis | ||
LTR5 Manual Looking for a copy of the manual for the Engel LTR5 pitch/depth controller | 0 | BuxtonRob | 322 | Sat Apr 01, 2023 12:49 pm by BuxtonRob | ||
What would be the right trim level | 2 | Michaelc | 1110 | Fri May 28, 2021 9:03 pm by Michaelc | ||
Making end caps | 13 | Tom(ADMIN) | 3567 | Thu Nov 19, 2020 3:20 pm by Cheapsub | ||
Krick Type Vll B Wiring and build photos Information | 2 | rwtdiver | 1353 | Fri Oct 09, 2020 3:15 pm by PeterJames | ||
Eden Dynamic WTC Refurbishment and battery layout | 0 | Deepdive | 1271 | Fri Apr 19, 2019 3:20 pm by Deepdive | ||
KRICK UBOOT DIVING PROCESS PUMP | 11 | KSIMODO | 1744 | Thu Aug 16, 2018 9:52 am by david f | ||
Level gyro help | 3 | BuxtonRob | 1565 | Wed Jan 31, 2018 9:11 am by BuxtonRob | ||
Prop RPM Help Requested | 6 | BuxtonRob | 1596 | Tue Jan 30, 2018 8:28 pm by BuxtonRob | ||
SubPirates Forum | 8 | John Wrennall | 4977 | Sun Nov 20, 2016 8:32 pm by Thor | ||
Typhoon Doesn't Like Water | 4 | timgarrod | 1641 | Mon May 02, 2016 5:58 pm by timgarrod | ||
engel depth limiter need to adjust | 2 | ginnis mick | 1903 | Wed Sep 30, 2015 9:37 pm by ginnis mick | ||
Another Dumb Question - Use of PVC for a WTC WTC | 3 | Radioman | 1780 | Tue Jul 07, 2015 9:53 pm by Radioman | ||
Cutting Hull Hull gap after cutting | 5 | Radioman | 3221 | Sun Jul 05, 2015 10:21 pm by Radioman | ||
Reproducing weld lines | 9 | Tom(ADMIN) | 4115 | Thu Jul 02, 2015 2:59 pm by merriman | ||
Depth control | 3 | bwi | 2505 | Wed Apr 08, 2015 8:51 pm by bwi | ||
Steering issue (maybe) | 4 | AdamD98 | 1823 | Tue Mar 24, 2015 6:59 pm by AdamD98 | ||
Hull Identification | 3 | John Wrennall | 1920 | Sat Nov 01, 2014 11:40 am by John Wrennall | ||
Camo paint jobs? | 0 | Tom(ADMIN) | 1806 | Wed Feb 12, 2014 6:20 pm by Tom(ADMIN) | ||
Cable gauge? | 1 | Tom(ADMIN) | 1836 | Mon Dec 23, 2013 7:37 pm by profesorul | ||
how to adjust photo | 7 | willte | 1924 | Wed Dec 18, 2013 5:42 pm by Tom(ADMIN) | ||
HOW TO CHOOSE a MOTOR BASED on the MODEL WE WANT to BUILD | 14 | profesorul | 1902 | Sat Nov 23, 2013 10:00 pm by Giovanni LiCalsi | ||
Flexible connectors? | 0 | Tom(ADMIN) | 1549 | Sun Nov 10, 2013 5:53 pm by Tom(ADMIN) | ||
Wiring/plumbing question. | 0 | Tom(ADMIN) | 1587 | Fri Oct 25, 2013 1:39 pm by Tom(ADMIN) | ||
Small Inflatable Bag | 4 | timgarrod | 2121 | Wed Aug 07, 2013 9:06 pm by timgarrod | ||
ballast and trimming | 10 | dgp1957 | 2986 | Mon May 06, 2013 8:27 pm by dgp1957 | ||
7-bladed propellers diameter at about 21 mm | 0 | Marcus Silva | 7534 | Sat Apr 20, 2013 5:40 pm by Marcus Silva | ||
SIMMERING & O-rings WHERE TO BUY | 2 | profesorul | 1982 | Thu Jan 31, 2013 6:15 pm by profesorul | ||
Engel Gato - Question about foreplane relay - Any ideas? | 1 | david f | 2316 | Wed Jan 16, 2013 10:56 am by david f | ||
Posting pictures and documents | 6 | david f | 3730 | Fri Jan 11, 2013 5:42 pm by profesorul | ||
robbie 212 class sub building | 0 | wadsworthj | 2552 | Tue Jan 01, 2013 2:46 pm by wadsworthj | ||
Newbies questions | 4 | Crossie | 2800 | Wed Dec 12, 2012 10:45 am by Crossie | ||
tee valves for vented dive systems tee valve | 1 | howard spary | 2224 | Fri Aug 31, 2012 8:14 am by Tom(ADMIN) | ||
web sites on the cheap | 3 | wadsworthj | 2154 | Wed Apr 11, 2012 8:43 pm by salmon | ||
Bath too small. | 1 | wadsworthj | 1748 | Sat Mar 24, 2012 10:45 pm by kraftykid | ||
Walther Type XVllB | 8 | ajg141 | 2319 | Fri Mar 23, 2012 5:44 pm by Tom(ADMIN) | ||
DESIGN with TurboCAD | 3 | profesorul | 2053 | Mon Mar 19, 2012 1:59 pm by profesorul | ||
Work bench ideas anyone? | 2 | david f | 1880 | Wed Mar 14, 2012 9:12 am by david f | ||
"Home" Test Tank - What if it is too small? | 21 | david f | 3641 | Mon Mar 12, 2012 11:00 pm by thegrimreaper | ||
30min epoxy | 13 | rgj | 2420 | Wed Mar 07, 2012 7:05 pm by Giovanni LiCalsi | ||
Mold materials/Cast Materials/How to use/Where can be Bought | 5 | profesorul | 2017 | Sun Mar 04, 2012 1:31 am by salmon | ||
Uzushio submarine possibility | 8 | Simon 007 | 3449 | Thu Mar 01, 2012 8:02 pm by tattooed | ||
Brushless motors - running in water | 20 | david f | 4706 | Mon Feb 20, 2012 10:33 am by david f | ||
Rotary shaft seals and stuffing box | 2 | 2051476 | 3950 | Fri Dec 30, 2011 3:12 pm by 2051476 | ||
212A Engel Kit Montage Problem for 212A | 1 | profesorul | 2717 | Fri Oct 14, 2011 8:14 pm by Tom(ADMIN) | ||
Interference, fuses etc. | 19 | Tom(ADMIN) | 3617 | Tue Jul 05, 2011 9:05 pm by Hermann | ||
Subs with twin props - alignment | 9 | david f | 2326 | Tue Jul 05, 2011 8:20 am by david f | ||
Drilling a vertical hole | 7 | Tom(ADMIN) | 2460 | Wed May 11, 2011 8:46 am by Tom(ADMIN) | ||
Reference pictures needed... | 8 | andyn | 2204 | Thu Apr 28, 2011 7:38 pm by andyn | ||
Grease/Oil? | 6 | Tom(ADMIN) | 2019 | Mon Apr 04, 2011 6:58 pm by Tom(ADMIN) |
Sort
Users browsing this forum: 0 Registered, 0 Hidden and 1 Guest
Registered Users: None
