Laser cut Robbe U47 conversion 14212712
In total there are 28 users online :: 0 Registered, 0 Hidden and 28 Guests :: 1 Bot
Laser cut Robbe U47 conversion EmptyTue Oct 29, 2024 4:46 pm by tsenecal
Laser cut Robbe U47 conversion EmptySun Oct 20, 2024 2:04 pm by geofrancis
Laser cut Robbe U47 conversion EmptyThu Oct 17, 2024 2:34 pm by geofrancis
Laser cut Robbe U47 conversion EmptyMon Oct 14, 2024 4:31 pm by geofrancis
Laser cut Robbe U47 conversion EmptySat Oct 12, 2024 3:52 pm by geofrancis
Laser cut Robbe U47 conversion EmptyFri Oct 11, 2024 8:58 pm by Marylandradiosailor
Laser cut Robbe U47 conversion EmptyFri Oct 11, 2024 8:14 pm by geofrancis
Laser cut Robbe U47 conversion EmptyThu Oct 10, 2024 3:21 am by tsenecal
Laser cut Robbe U47 conversion EmptyWed Oct 02, 2024 11:32 am by geofrancis
    subkraft
    Laser cut Robbe U47 conversion Empty Laser cut Robbe U47 conversion
    Post  subkraft Sun Jun 04, 2017 12:44 am
    New member, by way of introduction this is my latest project.  Long time ago converted to a piston tank, but never really successful. Wanted geared motors and tank to fill from forward so that it dived at better angle.
    Cad has been my day job so started long process of drawing parts and getting them laser cut.
    Laser cut Robbe U47 conversion U47_tu12
    Laser cut Robbe U47 conversion Parts_11
    Laser cut Robbe U47 conversion U47_tu13
    This has been an on / off project....but finally finished:
    Laser cut Robbe U47 conversion Uboat_14
    Laser cut Robbe U47 conversion Uboat_15
    Laser cut Robbe U47 conversion Uboat_16
    Laser cut Robbe U47 conversion Uboat_17
    Taking a different work direction into computer fabrication has meant I've now bought a co2 laser ....which has sped it up to completion.
    As pix show, parts are cut from 3mm acrylic and laminated.....now I'd probably 3d print some instead.
    Motors changed to 12v to keep amps down. Probably should have gone brushless for both drive and tank motors. The tank is slightly assymetrical to get clearance,  replacement with a smaller motor could have avoided this.
    So....next is to retrim.
    Pojoga and Les like this post
    Les
    Laser cut Robbe U47 conversion Empty Re: Laser cut Robbe U47 conversion
    Post  Les Tue Apr 09, 2024 12:54 am
    I really do like this conversion.
    I have just obtained a U47 and would like to upgrade it.
    Would you be willing to share your CAD drawings?
    Post  david f Tue Apr 09, 2024 3:40 pm
    Hi Les,
    Subkraft's post was a long time ago. I suggest it would be best to try emailing him.
      Current date/time is Thu Nov 21, 2024 6:26 am
