VICTOR III 14212712
VICTOR III 14212712
In total there are 36 users online :: 0 Registered, 0 Hidden and 36 Guests :: 1 Bot
VICTOR III EmptyTue Oct 29, 2024 4:46 pm by tsenecal
VICTOR III EmptySun Oct 20, 2024 2:04 pm by geofrancis
VICTOR III EmptyThu Oct 17, 2024 2:34 pm by geofrancis
VICTOR III EmptyMon Oct 14, 2024 4:31 pm by geofrancis
VICTOR III EmptySat Oct 12, 2024 3:52 pm by geofrancis
VICTOR III EmptyFri Oct 11, 2024 8:58 pm by Marylandradiosailor
VICTOR III EmptyFri Oct 11, 2024 8:14 pm by geofrancis
VICTOR III EmptyThu Oct 10, 2024 3:21 am by tsenecal
VICTOR III EmptyWed Oct 02, 2024 11:32 am by geofrancis
    VICTOR III
    bwi
    bwi
    VICTOR III Empty VICTOR III
    Post  bwi Mon May 07, 2018 9:48 pm
    After my AKULA, which was a learning project, I start another scratch built.
    As material I now use modeling board or Polyurethane board, it’s a very dens foam, comes in various densities. David Merriman got me hooked on it. I will never go back to any other material.
    The raw materials
    VICTOR III Axson_labelite_45pk_001
    Cutting the board up
    VICTOR III Cutting_axson_labelite_45pk_4_005
    The cutting resulted in a pile of blocks with were carefully labeled with purpose and dimensions. This stuff is expensive so you don’t want to end up with a huge pile of waste, so think before you cut and measure twice.
    VICTOR III Labelite-cut
    VICTOR III Labelite-labeled
    bwi
    bwi
    VICTOR III Empty Towed Array pod
    Post  bwi Mon May 07, 2018 9:53 pm
    The rough towed array pod.
    She is now resting in the "ready to paint and finish" box.
    missing but not forgotten, bushing for rudder, towed array exit hole, hatches
    VICTOR III Towed_Array_Pod_4_005
    VICTOR III Towed_Array_Pod_5_006
    VICTOR III Towed_Array_Pod_7_001
    bwi
    bwi
    VICTOR III Empty Stern master
    Post  bwi Mon May 07, 2018 9:57 pm
    Test fitting all the parts for the stern. No real issues found.
    Now the most time-consuming part to be dealt with, the alinement of the planes and rudders.
    Lessons learned from my AKULA, don't forget to give enough clearance to compensate for the primer that will be applied later and for the final paint coat applied when she will be finished.
    VICTOR III Stern_Assembly_3_001
    VICTOR III Stern_assembly001
    VICTOR III Stern_Assembly_2_002
    VICTOR III Diving-plane
    bwi
    bwi
    VICTOR III Empty stern moulds
    Post  bwi Mon May 07, 2018 10:13 pm
    Maybe a little bit to early to post this.......maybe it will not be exactly clear to everyone what I'm trying to achieve here.....It will become clear in time when I start the casting.
    My intention is to make the moulds by shaping some modeling board and use a thin jacked of silicone to take the shape of the stern master.
    The below picture show the support moulds in with the silicone will sit. I had plenty challenges here, I wanted to integrate index lips, cast the stern hollow by means of a caliber,......
    If it will work I don't know but at least I had fun designing it.
    All this resulted in two Articulated moulds.
    Dowel pins and pockets (clearance between them is 0.02 mm) I think I made close to 50 pc of them know....and counting
    VICTOR III Dowel-pin-_fabrication-001
    Caliber mould, with integrated dummy index lips
    VICTOR III Mould-caliber-001
    VICTOR III Muld-caliber-004
    the articulated master mould assembly
    VICTOR III Mould-masters-003
    All parts of the moulds
    VICTOR III Articulated_moulds
    bwi
    bwi
    VICTOR III Empty The Bow
    Post  bwi Tue May 15, 2018 7:46 pm
    The bow is taking shape.
    Grtz,
    Bart
    VICTOR III Bow_Upper_4
    VICTOR III Bow_Upper_3
    VICTOR III Bow_Upper_1
    VICTOR III Bow_Upper_2
    VICTOR III Bow_Complete_7
      Current date/time is Thu Nov 21, 2024 9:09 am
