Sheerline Akula 14212712
In total there are 22 users online :: 0 Registered, 0 Hidden and 22 Guests :: 1 Bot
Sheerline Akula EmptyTue Oct 29, 2024 4:46 pm by tsenecal
Sheerline Akula EmptySun Oct 20, 2024 2:04 pm by geofrancis
Sheerline Akula EmptyThu Oct 17, 2024 2:34 pm by geofrancis
Sheerline Akula EmptyMon Oct 14, 2024 4:31 pm by geofrancis
Sheerline Akula EmptySat Oct 12, 2024 3:52 pm by geofrancis
Sheerline Akula EmptyFri Oct 11, 2024 8:58 pm by Marylandradiosailor
Sheerline Akula EmptyFri Oct 11, 2024 8:14 pm by geofrancis
Sheerline Akula EmptyThu Oct 10, 2024 3:21 am by tsenecal
Sheerline Akula EmptyWed Oct 02, 2024 11:32 am by geofrancis
    Sheerline Akula
    thegrimreaper
    thegrimreaper
    Sheerline Akula Empty Sheerline Akula
    Post  thegrimreaper Tue Jan 11, 2011 5:48 pm
    The build log of my Sheerline Akula submarine
    Arrival of the box.
    Sheerline Akula Sdc10623
    Lots of packing keeping all inside safe.
    Sheerline Akula Sdc10624
    The two halves of the hull.
    Sheerline Akula Sdc10625
    Lots off little bags all nicely labeled as to what is in them.
    Sheerline Akula Sdc10626
    And of course the instructions.
    Sheerline Akula Sdc10627
    Bottom flood holes drilled out.
    Sheerline Akula Sdc10628
    Top flood slots cut out, not many on the Akula.
    Sheerline Akula Sdc10629
    Prop shaft support now in position.
    Sheerline Akula Sdc10630
    Sitting on its stand awaiting the drill, so as to drill the air release holes in the top of the hull.
    Sheerline Akula Sdc10713
    Front dive planes in position along with the WTC end stop in place.
    Sheerline Akula Sdc10714
    WTC rear end stop in position along with the prop support.
    Sheerline Akula Sdc10715
    Rudder and rear dive plane linkages in place along with loose lead ballast roughly in position.
    Sheerline Akula Sdc10716
    Rear lead ballast and center ballest loosely in position.
    Sheerline Akula Sdc10717
    Sheerline Akula Sdc10718
    Battery in position with front and rear end stops in place.
    Sheerline Akula Sdc10719
    WTC hold down velcro in place, the velcro replaces the brass strips and nut and bolts that used to come with this kit.
    Sheerline Akula Sdc10720
    This picture shows the top hull hold down bolt which sits over the prop shaft and is held in by resin.
    Sheerline Akula Sdc10721
    Tail pod and fin in position, the pod needs more holes in it than are shown here.
    Sheerline Akula Sdc10722
    Just another look at the pod and fin.
    Sheerline Akula Sdc10723
    Servo plate holding the water pump front dive plane push rod and the all important pinch valve and cam.
    Sheerline Akula Sdc10724
    Rear servo plate holding the drive motor, and also the rudder and rear dive plane push rods.
    Sheerline Akula Sdc10725
    A look at the conning tower(sail)and the periscopes made up from odds and ends from my bits box.
    Sheerline Akula Sdc10726
    After a bit of research on the great WWW, I found the correct position of the lights. Also found out that subs carry
    a flashing amber light for when they are on the surface, warning other ships that it is a surfaced sub with more under water than can be seen.
    Sheerline Akula Sdc10727
    The light system is two white leds, one on the front nose and the second on the rear pod with the
    usual red and green nav lights. The orange flashing light is in the wrong position but gives
    maximum visibility to surface targets, and is made from a small circuit board scrounged from a flashing display
    at a well known branch of chemist, all encased in resin and turned on by removing a small magnet from over two
    mocro reed switches on the front deck of the sub.
    Got the top and bottom catch done, it was not a simple job, in the end what I did was fix the bottom clip in place with resin, waited for it to set and then fitted the top clip to the bottom clip.
    I then ran a piece of insulation tape around both the clips. I then taped the top and bottom edges of the hull to catch any resin drips from the next step while the two clips were held together
    by the tape, I ran resin onto the edge of the top clip support plate then carefully lowered the top hull onto the bottom hull using tape on the outside to hold everything together.
    I hope that makes sense..when the resin is dry you need to borrow a long knife (carving) while her indoors ain't looking, slip the knife between the top and bottom hull joint and cut the insulation tape, you can then check the operation of the catch.
    Sheerline Akula Sdc10728
    Bottom clip.
    Sheerline Akula Sdc10729
    First bath test..this is fully submerged.
    Sheerline Akula Sdc10730
    Putting a bit of detail onto the deck, bits obtained from my bits box and the wifes sewing box (2X buttons).
    Sheerline Akula Sdc10731
    Went off to New Brighton on Sunday for her first run, I think she sits a bit low in the water at the
    moment, hopefuly this will be rectified soon.
    Sheerline Akula Sdc10732
    Sheerline Akula Sdc10733
    First bath test video...
    Well thanks for looking, hope you like the pics.
    Mark.
    Last edited by Richard(Admin) on Thu Jan 13, 2011 10:05 am; edited 6 times in total (Reason for editing : Pictures reinstated and post tidied up.)
    Sheerline Akula Empty Re: Sheerline Akula
    Post  Tom(ADMIN) Tue Jan 11, 2011 6:01 pm
    Excellent build log Mark, thanks for posting it up for all to see.
    Richard(ADMIN)
    Post  david f Tue Jan 11, 2011 6:53 pm
    Very nice log.
    I think I read somewhere that subs are the only vessels to have flashing navigation lights.
    How long did it take to build her?
    thegrimreaper
    thegrimreaper
    Post  thegrimreaper Tue Jan 11, 2011 7:08 pm
    Build took approx 2 1/2 months but still not quite finished as to the flashing orange light according to Wikki subs carry the same nav lights as ships and boats red green and white lights at the front and second white light at the highest point of the vessel with an orange strobe light in a prominent position so other vessels know that they are approching a submarine and the submarine could be longer than the approching vessel`s capt assumes or words to that effect
    I thought to put lights on it would be a good idea anyway just to be different
    glad you liked the log
    regards Mark
    Post  david f Thu Jan 13, 2011 12:23 pm
    2 1/2 months sounds very good and it looks very nice.
    I have never built a Sheerline sub but I must say I like their design and rugged construction.
    One way or another it has influenced my own sub models. (Copying could be the most sincere type of flattery!)
    thegrimreaper
    thegrimreaper
    Post  thegrimreaper Wed Jan 26, 2011 6:40 pm
    O.k. got the Akula in the water at New Brighton at the week-end went well but did not dive due to a radio glitch (cough cough dont ask )now fitted an auto leveler and the must have fail-safe going to croydon next week for a pool run will have more pics and possibly a video as well
    link to video https://www.youtube.com/watch?v=c2as3JS00dY
    regards Mark
    Post  Tom(ADMIN) Wed Jan 26, 2011 6:44 pm
    She does look good in the water Mark, we're all looking forward to seeing some video of her going under.
    Mr2Rich
    Mr2Rich
    Post  Mr2Rich Wed Jan 26, 2011 8:56 pm
    Yep she looks nice and clean good luck for the under water test.
    thegrimreaper
    thegrimreaper
    Post  thegrimreaper Thu Mar 22, 2012 12:43 pm
    Just a bit of an update on the running of the Akula...it's now been a while since I built this model. The sub was laid up over the winter, and on Sunday 18 March she was brought out of hibernation and given the once over. Once the batteries were fully charged, it was off to New Brighton with her...my plan was to sail the new Vanguard I have built, but due to radio problems this didn't happen, so here is a video of my Akula after a quick visual inspection and battery charge.
    Hope you like...
    https://www.youtube.com/watch?v=Azf4nQWSgck&feature=youtu.be
    Regards,
    Mark
    Post  Tom(ADMIN) Thu Mar 22, 2012 1:31 pm
    Very nice video Mark, very professionally done (the wife, I take it?) The Akula runs nice, she's very stable, isn't she?
    Nice mate...very nice.
    Rich
    rcyard
    rcyard
    Sheerline Akula Empty Looking for the manual
    Post  rcyard Fri Jul 07, 2023 12:43 am
    I'm looking for the assembly manual of this submarine. I see it in your photos. Can you share these documents?
    Post  david f Fri Jul 07, 2023 1:32 pm
    Hi rcyard,
    You may try Becks Model Marine for information?
    They took over Sheerline's interests a few years back. Since then I have rather lost touch with them so you would do us all a favour in reporting back here.
    rcyard
    rcyard
    Post  rcyard Mon Aug 07, 2023 11:37 am
    david f wrote:Hi rcyard,
    Hi David,
    I tried it and I got the manual from Beck's Marine. Thank you.
      Current date/time is Thu Nov 21, 2024 8:57 am
