Water jet Manouvering thusters 14212712
In total there are 46 users online :: 0 Registered, 0 Hidden and 46 Guests :: 2 Bots
Water jet Manouvering thusters EmptyTue Oct 29, 2024 4:46 pm by tsenecal
Water jet Manouvering thusters EmptySun Oct 20, 2024 2:04 pm by geofrancis
Water jet Manouvering thusters EmptyThu Oct 17, 2024 2:34 pm by geofrancis
Water jet Manouvering thusters EmptyMon Oct 14, 2024 4:31 pm by geofrancis
Water jet Manouvering thusters EmptySat Oct 12, 2024 3:52 pm by geofrancis
Water jet Manouvering thusters EmptyFri Oct 11, 2024 8:58 pm by Marylandradiosailor
Water jet Manouvering thusters EmptyFri Oct 11, 2024 8:14 pm by geofrancis
Water jet Manouvering thusters EmptyThu Oct 10, 2024 3:21 am by tsenecal
Water jet Manouvering thusters EmptyWed Oct 02, 2024 11:32 am by geofrancis
    Water jet Manouvering thusters Empty Water jet Manouvering thusters
    Post  geofrancis Thu Nov 04, 2021 12:37 am
    I am workng on an autonomous  boat that can dynamically hold position using gps. the key to making it work was discovering car windscreen washer pumps with dual outlets. these pumps can be found online for less than £10 and run best at 12-15v. basically if you spin them one way it comes out one nozzle, spin it the other way and it comes out the other one, this is originally used for a cars front and rear window washer but it works ideal as a high-pressure water jet manoeuvring system without any external propellers or drives that can snag, i though this might be usefull to anyone wanting a compact way of adding bow and stern thrusters to their submarines. I originally started using car washer pumps on my nitro boats years ago for when the engine cut out on the pond I could use it as an auxiliary jet drive to make it back to the side of the pond. Because it used 6mm water inlets and 4mm outlet there was very little extra drag.
    Water jet Manouvering thusters A15404727-121-s-l1600
    SimonH likes this post
    Water jet Manouvering thusters Empty Re: Water jet Manouvering thusters
    Post  david f Sat Nov 06, 2021 11:16 am
    Interesting approach.
    Would the water jet provide more thrust if it discharges into water?
    The jet discharging over the rudder is interesting too. Does it reduce the turning circle?
    Another use for these would be for model subs at exhibitions (Yes - exhibitions are back e.g Blackpool.)
    Display ponds are small and many subs have poor turning circles. You get my drift.
    Post  geofrancis Sun Nov 07, 2021 8:13 pm
    david f wrote:Interesting approach.
    As far as I know discharging the jets will give the same force above or below the surface as your not pushing against the water but using the expelled water as reaction mass. in my videos the boat is almost empty so they are well above the surface but should be just below the waterline when loaded up.
    the jet of water directly onto the rudder should give the effect of vectored thrust, giving the rudder more authority especially at low speed. there is also another outlet for reverse at the front of the keel.
    this is a full sized version that i found.
    Post  geofrancis Sat Nov 27, 2021 4:50 pm
    i made a small video to show it manoeuvring, once the deck is on and its fully loaded the thrusters will be underwater and barely visible.
      Current date/time is Thu Nov 21, 2024 11:25 am
