Prop shaft stuffing box 14212712
In total there are 11 users online :: 0 Registered, 0 Hidden and 11 Guests :: 1 Bot
Prop shaft stuffing box EmptyTue Oct 29, 2024 4:46 pm by tsenecal
Prop shaft stuffing box EmptySun Oct 20, 2024 2:04 pm by geofrancis
Prop shaft stuffing box EmptyThu Oct 17, 2024 2:34 pm by geofrancis
Prop shaft stuffing box EmptyMon Oct 14, 2024 4:31 pm by geofrancis
Prop shaft stuffing box EmptySat Oct 12, 2024 3:52 pm by geofrancis
Prop shaft stuffing box EmptyFri Oct 11, 2024 8:58 pm by Marylandradiosailor
Prop shaft stuffing box EmptyFri Oct 11, 2024 8:14 pm by geofrancis
Prop shaft stuffing box EmptyThu Oct 10, 2024 3:21 am by tsenecal
Prop shaft stuffing box EmptyWed Oct 02, 2024 11:32 am by geofrancis
    Prop shaft stuffing box Empty Prop shaft stuffing box
    Post  Tom(ADMIN) Fri Mar 04, 2011 6:05 pm
    I've just found in my spares box a Sub Tech "SBS-2 Prop Shaft Stuffing Box with seals"...it seems to be a length of brass tube about 2" long with bronze bushes either end, and two internal O ring seals. According to the brief instructions, it must be fitted in one way only, which is described on the packet.
    I'm guessing it would take a 1/4" prop shaft, which I could then connect to the stub shaft by using a standard Huco type coupling.
    I take it that this can be fitted into the end cap of a wtc, with the prop shaft passing through it to make a water tight seal?
    Anyone ever used one of these?
    Prop shaft stuffing box Dsci0083
    Last edited by Richard(Admin) on Sat Mar 05, 2011 10:22 am; edited 1 time in total (Reason for editing : Image added)
    Prop shaft stuffing box Empty Re: Prop shaft stuffing box
    Post  Tom(ADMIN) Mon Mar 07, 2011 12:27 pm
    Having had a chat to Mark @ MMB, he's now making me up a shaft for the stuffing box, which incidentally measured at 5mm, he's also making the 4mm main prop shaft as well, should be here in a couple of days time.
      Current date/time is Thu Nov 21, 2024 10:11 am
