Converting a 35Mhz dual conversion receiver (Futaba) to 40Mhz 14212712
In total there are 24 users online :: 0 Registered, 0 Hidden and 24 Guests
Converting a 35Mhz dual conversion receiver (Futaba) to 40Mhz EmptyTue Oct 29, 2024 4:46 pm by tsenecal
Converting a 35Mhz dual conversion receiver (Futaba) to 40Mhz EmptySun Oct 20, 2024 2:04 pm by geofrancis
Converting a 35Mhz dual conversion receiver (Futaba) to 40Mhz EmptyThu Oct 17, 2024 2:34 pm by geofrancis
Converting a 35Mhz dual conversion receiver (Futaba) to 40Mhz EmptyMon Oct 14, 2024 4:31 pm by geofrancis
Converting a 35Mhz dual conversion receiver (Futaba) to 40Mhz EmptySat Oct 12, 2024 3:52 pm by geofrancis
Converting a 35Mhz dual conversion receiver (Futaba) to 40Mhz EmptyFri Oct 11, 2024 8:58 pm by Marylandradiosailor
Converting a 35Mhz dual conversion receiver (Futaba) to 40Mhz EmptyFri Oct 11, 2024 8:14 pm by geofrancis
Converting a 35Mhz dual conversion receiver (Futaba) to 40Mhz EmptyThu Oct 10, 2024 3:21 am by tsenecal
Converting a 35Mhz dual conversion receiver (Futaba) to 40Mhz EmptyWed Oct 02, 2024 11:32 am by geofrancis
    Converting a 35Mhz dual conversion receiver (Futaba) to 40Mhz Empty Converting a 35Mhz dual conversion receiver (Futaba) to 40Mhz
    Post  david f Sat Jul 16, 2011 11:16 am
    Dear John,
    (That sounds good!)
    Anyone know if this can be done simply?
    (There must be a few 35Mhz receivers of limited use abou the place now. Mine is fairly recent and cost quite a lot of money.)
    johnrobinson
    johnrobinson
    Converting a 35Mhz dual conversion receiver (Futaba) to 40Mhz Empty changing 35mhz to 40 mhz fm
    Post  johnrobinson Sun Jul 17, 2011 4:41 pm
    HI David
    It is strange that you have asked this because i have just changed this week a 35 mhz futaba receiver to 40 mhz fm, for some thing i wonted to do in most cases the osillator for the 35 mhz crystal will retune to 40 mhz with no modes but you will have to change a couple of caps to a smaller value on front end of RX input and retune to 40 mhz can be done in ten mins
    john
    Converting a 35Mhz dual conversion receiver (Futaba) to 40Mhz Empty Graupner 40MHz Radio to Synthesized 75MHz
    Post  Giovanni LiCalsi Mon Jul 18, 2011 4:34 am
    Across the pond in the USA we use 75MHZ for submarine use and I am converting a Graupner 40MHz radio to this frequency. The RF module, that I am using, is a HiTec Spectra Synthesized 75MHz RF.I'm wondering if there is a twin-stick, similar to my Robbe Nautical F-14, available to convert this radio?
    Kind regards,
    Giovanni
    Converting a 35Mhz dual conversion receiver (Futaba) to 40Mhz CIMG2347
    Converting a 35Mhz dual conversion receiver (Futaba) to 40Mhz 20
    johnrobinson
    johnrobinson
    Converting a 35Mhz dual conversion receiver (Futaba) to 40Mhz Empty converting TX unit
    Post  johnrobinson Mon Jul 18, 2011 6:55 pm
    HI Giovanni
    You could try converting a FC-18 ROBBE FUTABA as i reworked one to work on 458 mhz to use in uav plane its a pitty you guys in the U.S.A use 75mhz would be better off on lower bands, what sort of power level are you allowed to use in the UK it is 100mw ERP
    john
    Converting a 35Mhz dual conversion receiver (Futaba) to 40Mhz Empty Re: Converting a 35Mhz dual conversion receiver (Futaba) to 40Mhz
    Post  david f Tue Jul 19, 2011 9:32 am
    Hi John,
    I have a 35Mhz Futaba Dual Conversion, 8 channel receiver which I would like to have converted to 40MHz.
    I will pm you about it.
    Post  Giovanni LiCalsi Wed Jul 20, 2011 7:17 am
    johnrobison wrote: HI Giovanni
    john
    Hello John,
    It seems that the mv limit is a mystery in the USA!
    Just type into the www.RCgroups.com search box and be dazed and confused!
    Please show me the Robbe FC-18 twin-stick conversion? I'm dying to add this to my Graupner MC-19.
    Regards,
    Giovanni
      Current date/time is Thu Nov 21, 2024 9:26 am
