I was puzzled with my twin propped U Class (ORP Dzik). One motor kept on shutting down after a few minutes.
On investigation, I realised that I had stupidly forgotten to do the necessary modification to one of the ESCs. You need to do this when you use them with a separate BEC.
You need to remember to cut the red wire (AAAgh not the blue one - BOOM! (Sorry!) on the lead to the receiver.
And then it is best to cut off the switch and solder both leads together.
