Two dive plane protectors,these are fitted just in front of the very large dive planes.
In total there are 6 users online :: 0 Registered, 0 Hidden and 6 Guests :: 1 Bot
12 posters
CSS HUNLEY
- Post n°126
Re: CSS HUNLEY
- Post n°127
Re: CSS HUNLEY
The strange rudder with the slot in it,the rudder arangement is a little strange.
- Post n°128
Re: CSS HUNLEY
The very large dive planes awaiting triming you can see the flash from the mould on one end.
- Post n°129
Re: CSS HUNLEY
The forward tower bonded into place and rough trimmed,also showing the water inlets with brass collets fitted.
- Post n°130
Re: CSS HUNLEY
Another view of the forward tower this also shows the bushing for the dive planes on the waist band.
- Post n°131
Re: CSS HUNLEY
The rear tower fitted,allso shows two of the port holes that run along along the top of the hull these will have the larger port hole rings fitted around them in keeping with the original.
- Post n°132
Re: CSS HUNLEY
With the larger port hole cappings fitted.
- Post n°133
Re: CSS HUNLEY
Tail with prop shaft loosly fitted,the top brass tube is part of the rudder assembly.
- Post n°134
Re: CSS HUNLEY
Another veiw of the rear end.
- Post n°135
Re: CSS HUNLEY
Forgot to add a photo of tower before it was trimmed and fitted.
- Post n°136
Re: CSS HUNLEY
Some views of the strange rudder arrangement,which now works very well.
- Post n°137
Re: CSS HUNLEY
- Post n°138
Re: CSS HUNLEY
- Post n°139
Re: CSS HUNLEY
- Post n°140
Re: CSS HUNLEY
- Post n°141
Re: CSS HUNLEY
- Post n°142
Re: CSS HUNLEY
- Post n°143
Re: CSS HUNLEY
- Post n°144
Re: CSS HUNLEY
- Post n°145
Re: CSS HUNLEY
- Post n°146
Re: CSS HUNLEY
- Post n°147
Re: CSS HUNLEY
Giovanni LiCalsi- Guest
- Post n°148
Re: CSS HUNLEY
The articulated rudder is really a marvel of engineering !
I'm lusting after this model. Hoping you may offer some kits ?
- Post n°149
Re: CSS HUNLEY
Some views of the spar torpedo shaft and mounting.
- Post n°150
