In total there are 54 users online :: 0 Registered, 0 Hidden and 54 Guests :: 3 Bots
12 posters
CSS HUNLEY
- Post n°51
Re: CSS HUNLEY
- Post n°52
Re: CSS HUNLEY
- Post n°53
Re: CSS HUNLEY
Second side gel coated.
- Post n°54
Re: CSS HUNLEY
profesorul- Guest
- Post n°55
Re: CSS HUNLEY
HI,
I am not familiarized with these technique.
What's GEL COAT for?,
You make it red or is his color?,
- Post n°56
Re: CSS HUNLEY
The mould's awaiting triming.
- Post n°57
Re: CSS HUNLEY
- Post n°58
Re: CSS HUNLEY
- Post n°59
Re: CSS HUNLEY
Looking very good , Nigel!
- Post n°60
Re: CSS HUNLEY
profesorul wrote:HI,
Hi Marius,
Gel is a thick resin about the same as syrup,it is used as the surface you see on the finished product,it remains tacky on the air side and full dryes on the surface that is in contact with the mould or patten,this is to help it bond to the matt it also stops the patten of the matt showing through the surface,it can be bought in color but I buy it clear and color it myself,I colored it red in this case as the boat will be colored black this helps to make sure the mould has been covered with the black gel properly as the red is clearly visable through the black if you have missed a bit.
- Post n°61
Re: CSS HUNLEY
The finished moulds covered in black gel coat awaiting matt.
- Post n°62
Re: CSS HUNLEY
Another view wit gel on.
- Post n°63
Re: CSS HUNLEY
- Post n°64
Re: CSS HUNLEY
Very nice work, mate...very impressive.
- Post n°65
Re: CSS HUNLEY
Moulds with the matt laminated in.
- Post n°66
Re: CSS HUNLEY
Another view with the matt and resin applied.
- Post n°67
Re: CSS HUNLEY
And another.
- Post n°68
Re: CSS HUNLEY
Half hull's and centre section removed from mould after cureing.
- Post n°69
Re: CSS HUNLEY
A few more views of the hulls.
- Post n°70
Re: CSS HUNLEY
profesorul- Guest
- Post n°71
Re: CSS HUNLEY
HI,@nigele
THANK YOU.Now is clear.Is a lot of work before You get the final product!.
But from what I can see until now is great and specially so accurate.
How thick it wheel be the hull?;how many layers of fiberglass You add?;
I've seen in the pictures You used fist a dense fiberglass cloth and then a different fiberglass!.
I have a question:
-how You wheel join the 2 half in length,I mean how is going to be align?.
Or just a upper hull is made in 2 pieces and the lower hull is in one piece in length?.
MARIUS.
I have a question:
MARIUS.
- Post n°72
Re: CSS HUNLEY
Hull taped together to check fit after trimming.
- Post n°73
Re: CSS HUNLEY
Another view of hull.
- Post n°74
Re: CSS HUNLEY
Another view of the hull showing the joint line which will be laminated with resin and matt.
- Post n°75
Re: CSS HUNLEY
the hulls seperated again to be washed and fitted back in the mould to be joined.
