Engel Gato - Question about foreplane relay - Any ideas? 14212712
In total there are 14 users online :: 0 Registered, 0 Hidden and 14 Guests :: 1 Bot
Engel Gato - Question about foreplane relay - Any ideas? EmptyTue Oct 29, 2024 4:46 pm by tsenecal
Engel Gato - Question about foreplane relay - Any ideas? EmptySun Oct 20, 2024 2:04 pm by geofrancis
Engel Gato - Question about foreplane relay - Any ideas? EmptyThu Oct 17, 2024 2:34 pm by geofrancis
Engel Gato - Question about foreplane relay - Any ideas? EmptyMon Oct 14, 2024 4:31 pm by geofrancis
Engel Gato - Question about foreplane relay - Any ideas? EmptySat Oct 12, 2024 3:52 pm by geofrancis
Engel Gato - Question about foreplane relay - Any ideas? EmptyFri Oct 11, 2024 8:58 pm by Marylandradiosailor
Engel Gato - Question about foreplane relay - Any ideas? EmptyFri Oct 11, 2024 8:14 pm by geofrancis
Engel Gato - Question about foreplane relay - Any ideas? EmptyThu Oct 10, 2024 3:21 am by tsenecal
Engel Gato - Question about foreplane relay - Any ideas? EmptyWed Oct 02, 2024 11:32 am by geofrancis
    Engel Gato - Question about foreplane relay - Any ideas? Empty Engel Gato - Question about foreplane relay - Any ideas?
    Post  david f Sun Jan 13, 2013 10:42 am
    Message below posted from an AMS member Bill. Anyone got any ideas please reply here:
    A new foreplane relay called an RMR, engel no8440. wired as per drawing, until it comes to ground pin.they sent me a 4 channel switch module item no8431 one end goes to rx the other end is the problem? do i just put the wire from RMR to ground? or use the switch module, and if so, how is it used,? it shows neg to battery and 4 pozi channels with a jumper, all i need is ground ,i take it, anybody else using this upgrade on their gato boats could possibly solve the problem, hope you can help,bill.
    Engel Gato - Question about foreplane relay - Any ideas? Empty Re: Engel Gato - Question about foreplane relay - Any ideas?
    Post  david f Wed Jan 16, 2013 10:56 am
    I have had a look at the circuit diagram and yes it looks as if you should connect the ground connection to ground (battery negative.)
      Current date/time is Thu Nov 21, 2024 10:02 am
